Author Topic: Battery re-location  (Read 4050 times)
Offline JZEROE
Battery re-location
« on: December 07, 2008, 10:30:20 PM »
Hi there.
So next weekend I'm stripping the 550 down to send the frame off the powedercoater's (quick poll: red or chrome?), and I've been thinking a lot about the battery. I hate the sidecovers. I want to move the battery, but I don't want to put it cafe-style under the seat, because I need to be able to give rides to the girl. Any opinions about where to put it? I was thinking of moving the battery down to on top of the swingarm, between the two sides of the frame instead of hanging out the side. Better for balance and center of gravity, yes? Any ideas/advice?
Thanks.
J
'75 CB400F
'76 CB750K - Project Freebike
Re: Battery re-location
« Reply #1 on: December 07, 2008, 10:33:50 PM »
Should be room under the swingarm I think, if you use small battery and  no e-start. That is where I want mine..
Offline Shenanigans
  • Right turn?
« Reply #2 on: December 07, 2008, 10:51:59 PM »
Also you can get a smaller gel battery so you can lay it flat under the seat.
« Last Edit: December 07, 2008, 10:54:53 PM by Shenanigans »
Offline DollarBill
« Reply #3 on: December 08, 2008, 04:10:48 AM »
With the smaller gel batteries are you able to use the electric start?  How are they on life and do they charge well using the bikes charging system?
1975 CB750F Project Yellow Jacket - CBR600rr Swinger GSXR 600 Forks
1955 BMW R25/3, 1966 Honda CA160, 1975 CB400f, 1975 CB550, 1976 CB550
Offline tygrant
« Reply #4 on: December 08, 2008, 05:40:06 AM »
i would say they are equal on charge and power but you dont have to worry about the acid pooring out everywhere if you tip them every wich way.
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline my78k
« Reply #5 on: December 08, 2008, 06:59:20 AM »
Shenanigans, is that the set up on the bike you took on your trip this summer? Or is that on your other bike?
Dennis
Offline JZEROE
« Reply #6 on: December 08, 2008, 07:28:31 AM »
Sweet solution--thanks! What did you do with the electrical panel?
'75 CB400F
Offline noose74
  • cafe racer
« Reply #7 on: December 08, 2008, 08:57:53 AM »
i had BCR make me a battery box that sits basically on top of the swing arm...the rest of the elecricals are under the rear seat...i went with a 2 seater with removable cowl cuz my wife likes to ride but i wanted a cafe bike and love the look of the openess under the seat... heres a pict
Offline JZEROE
« Reply #8 on: December 08, 2008, 10:33:58 AM »
That's awesome, and the weight distribution is what I'm looking for. Do you have a pic of the bike from the side, so I can get a better sense of the appearance when put-together?
'75 CB400F
Offline Jim F
  • go baby go
« Reply #9 on: December 08, 2008, 02:48:59 PM »
I didn't think the small gel type battery's could handle the starter
I do like the battery location near the swing arm though
is that the stock size battery?
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline d3buttz
  • More than just an
« Reply #10 on: December 08, 2008, 03:49:52 PM »
i wouldnt recommend sending the frame off to the p.coaters untill you relocate the battery for sure with your new battery mount brackets(bolted or welded)and in your bike completely together.  or even any other custom stuff you do-build your bike complete first the way you want- then take it apart and paint. i built this box for my battery and electric card and i had to weld up 4 mount tabs to bolt it to the frame. id be a shame to ruin all the powder coating by touching it up with crappy regular paint over tabs. good luck!
http://forums.sohc4.net/index.php?topic=80508.0
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1996 Nissan pathfinder
1972 Datsun 240z
2002 Nissan sentra se-r spec-v
Offline Shenanigans
  • Right turn?
« Reply #11 on: December 08, 2008, 04:59:44 PM »
Dennis
Thats on the bike I took on my trip and this setup never gave me any trouble.
All the wires you see there are all the bikes electrics except for the Reg./Rec. that is mounted underneath next to the key switch.
You can use the electric start but your bike better be easy to start or you will soon run your battery dead. I think about 6AH is the lowest you want to go. I dont think it would handle stop and go traffic for extended periods of time.
Offline ieism
« Reply #12 on: December 10, 2008, 04:51:35 PM »
I used an 8Ah Odessey battery. It has enough power to start the bike easily, but I can't use the starter for more then 30 seconds. The battery does charge rather fast, so i've had no problems riding in slow traffic . In fact, the bike wouldn't start on the e-start the other day, so I kept trying untill it was nearly dead. I then realized a stuck float was the problem and eventually started it with the kickstarter. I took off and 10 minutes later the battery had enough power to work the starter already. This is the best battery i've ever had, on any bike. They are more expensive but IMO well worth it.
---cb550---
Offline doobiebro
« Reply #13 on: December 11, 2008, 10:45:21 AM »
If one were to keep the liquid acid type battery and relocate it to the top of the swingarm, would the vibrations and jolts from the swingarm movement lead to premature failure of the battery?
Offline KB02
« Reply #14 on: December 11, 2008, 03:26:06 PM »
Red.
No one else has posted an opinion yet on color choice.  ;D
As for the battery, I would avoid placing it actually on the swing arm (I could be mis-interpreting that) as you will get a lot of bumps and jolts that a battery won't really care for. Lower CG and cteralized weight is always a good thing, though.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
