Author Topic: Help with Tire Tube Size  (Read 1163 times)
Offline JerryRice
« on: December 10, 2008, 07:36:07 AM »
I am interested in getting these tires:
http://www.motorcycle-superstore.com/1/28/396/12107/ITEM/Avon-AM26-Roadrider-Rear-Tire.aspx
But what size tubes do I get? Does it go by the same size as the tire?
For ex if I get 110/90 18. Do I get the same tube size?
Thanks!
« Last Edit: December 10, 2008, 07:45:12 AM by JerryRice »
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline JerryRice
Re: Help with Tire Tube Size
« Reply #1 on: December 10, 2008, 08:06:59 AM »
Anyone here familiar with tubes?
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline HondanutRider
« Reply #2 on: December 10, 2008, 08:21:02 AM »
Tubes are sized the same as the tires, except that usually there is a slight range of tire sizes that one tube size will cover (because tubes can stretch in inflation).  The manufacturer will include this "range" of sizes in the specs for their tubes as well as printing them on the carcass.  As well, there are two methods of listing tire sizes: one is as you quote (the newer method, e.g. 110/90-18) and the older method (e.g. 3.50X18).  These two methods have equivalent sizes (not certain if what I've quoted are equivalent); but, you usually want to stick with the same for tire and tube to be sure of a good match.
To answer directly your question: yes, go by the same size as the tire for your tube.
Offline JerryRice
« Reply #3 on: December 10, 2008, 08:27:25 AM »
Thanks alot for the advice!
The Real JERRY RICE
My Dream Bike
www.CB350F.com
« Reply #4 on: December 11, 2008, 06:27:10 AM »
Glad to be of help.  (Now if someone can help me with my "muffler drain-hole" question...)
