Author Topic: Battery drain hose placement 76 cb750  (Read 1568 times)
Offline cijiwij
« on: September 28, 2005, 05:18:24 PM »
There is  a rubber tube in the battery box and it appears that the battery drain hose should go inside it. Is this true..
Offline Lumbee
    • My pics...
Re: Battery drain hose placement 76 cb750
« Reply #1 on: September 29, 2005, 02:23:37 PM »
 ???  Doesn't sound right to me.  Is there such a thing as a battery drain tube installed on the bike?  what is the tube connected to on the other end?
"I'm not a welder, but I play one on HondaChopper.com"
Offline scondon
  • Mmmm......tasty bugs
« Reply #2 on: September 29, 2005, 07:46:36 PM »
As far as I know there are two tubes poking up around the battery box. One is clear yellow and attaches to the gas tank overflow tube on one end and* routes back to the exhaust mounting bracket by the rear wheel *(77-78 750F). The other one is the battery breather tube which is black rubber, mine has a metal insert in the tip.
    TRUE
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
« Reply #3 on: September 29, 2005, 09:12:51 PM »
I rerouted mine so if the battery ever boiled the acid would not hit my pipes, (worth more than the bike)  it is longer than it was orig and stiffer.  it runs 1 inch from the rear tire so the acid will collect on the tire and sling off (hopefully) away from the 4 to4 pipes.
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
