Author Topic: 750 engine number confusion  (Read 2186 times)
Offline fmctm1sw
« on: December 16, 2008, 06:57:55 PM »
Not that it should be the most important thing to me but my engine number is CB750E-2520720.  I don't see that anywhere in this handy chart:  http://hondachopper.com/modifications.html
No 25 anything for that matter...
Ah crap.  Nevermind.  Probably in the same line as 2470427 (K6 I guess)
« Last Edit: December 16, 2008, 07:07:02 PM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline mystic_1
  • 1970 CB750K
Re: 750 engine number confusion
« Reply #1 on: December 16, 2008, 07:12:49 PM »
Sounds right to me.  The numbers on that chart are read as "Change applies to this engine number and later."
mystic_1
- John Augustus Shedd
Online Kevin D
  • SE Michigan
« Reply #2 on: December 16, 2008, 07:23:26 PM »
Any chance there is an "F" tucked in there somewhere??:
About the CB750F
Serial Numbers
Model Year     Frame #                      Engine #
750F0           1975 CB750F-1000002 - CB750FE-2500004 -
750F'76         1976 CB750F-2000003 - CB750FE-2515094 -
750F'77         1977 CB750F-2100011 - CB750FE-2600004 -
750F'78         1978 CB750F-2200001 - CB750FE-3100001 -
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline fmctm1sw
« Reply #3 on: December 17, 2008, 04:38:38 AM »
About the CB750F
Serial Numbers
Yeah, I did look real close.  No "F" in there for sure...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #4 on: December 17, 2008, 05:22:13 AM »
Any possibility the cases were replaced? I think fresh cases from Honda don't have a number on them. Then a safe area would be chosen to stamp a number since it is virtually meaningless anyway. That is it is not a legal identifier for registration purposes, but we use it for modification purposes.
THis is simply a WAG. What does your frame say it is, just curious.
Offline fmctm1sw
« Reply #5 on: December 17, 2008, 08:50:21 AM »
My frame is:  CB750-2331942.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #6 on: December 17, 2008, 09:01:28 AM »
1974 frame
1976 engine
« Reply #7 on: December 17, 2008, 09:08:32 AM »
According to "The Restorers Guide to K and F Series" by John Wyatt, that puts your chasis as a K4, offered in 1974, though some may be titled 1975. K5s start at frame number 2500001.
The engine number is likely a K6, they start at 2428762 and K7 starts at 2700001. Seems a pretty broad range there... still Likely a K6.
FYI: Engine modifications did not always occur at model change points. Some could be mid-model run.
Offline tbpmusic
« Reply #8 on: December 17, 2008, 09:18:05 AM »
There are states that use the engine number for Title purposes.
I think Wisconsin is one of them, from what I've been told - of course that's anectdotal information.
bill2
"If you can't fix it with a hammer, then it's an electrical problem"
Bill Lane
 '71 CB450 Mutant/ '75 CB200/ '81 CM200/ '71 C70M
« Reply #9 on: December 17, 2008, 09:48:32 AM »
bill2
That would be problematical for some, not for us Hoosiers. Likely those records could be updated if necessary.
