Do you have the upgraded cam covers or the original type?
Do you have eight rods or four?
Do you have the pinch bolts in the cam cover?
If you have the old style, are the rod bores worn? Are you inserting the rods with the screw hole out? And, is the valve spring pressure keeping the rods from sliding?
