Author Topic: will it fit?  (Read 1477 times)
Acid0atm3al
will it fit?
« on: December 22, 2008, 01:51:07 PM »
i found an exhaust locally for a 80 cb650c, and i was wondering if there was any way it would fit my cb750k?
Acid0atm3al
Re: will it fit?
« Reply #1 on: December 22, 2008, 01:51:36 PM »
oh, and my 750k is also an 1980
Offline scunny
  • don't call me expert
Re: will it fit?
« Reply #2 on: December 22, 2008, 01:54:27 PM »
only if the exhaust spacing and angle of the ports is the same, I think you will be down on diameter of the headers as well
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Re: will it fit?
« Reply #3 on: December 22, 2008, 08:50:43 PM »
If you can get them on, you might not need a sidestand. :o
The 650 motor is straight up I believe and the 750 slanted so your mufflers may touch the ground or be level..
Offline crazypj
  • I'm brill, me
Re: will it fit?
« Reply #4 on: December 23, 2008, 09:19:25 PM »
NO
Offline Soos
Re: will it fit?
« Reply #5 on: December 24, 2008, 02:26:24 AM »
NOpe.
Tried a DOHC740 exhaust on my cb650, it's close, but no cigar.
However with enough welding and fabricating a few parts, almost anything is possible.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline johnny_from_bel
  • Member #158
Re: will it fit?
« Reply #6 on: December 24, 2008, 02:54:37 AM »
NOpe.
l8r
That is what I did. Machined new headers, cut the pipes and welded everything back together.
Re: will it fit?
« Reply #7 on: December 24, 2008, 10:40:34 AM »
Pipes pretty well NEVER interchange.
One thing the 750 has that most motors dont is splayed EX ports, most motors they come out more straight line...
 Yeah, you can modify lots of other stuff to fit but more often than not it looks  a bit cobby.. if you are really good at it, then you could build from scratch anyway..
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: will it fit?
« Reply #8 on: December 24, 2008, 10:56:55 AM »
I'll second that... 750's are about the hardest bike to modify pipes for. It's acutally EASIER to fab up your own than modify a set of collectors.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
