Author Topic: Is this set of 750 cases now trash?  (Read 6831 times)
Offline bunghole
Re: Is this set of 750 cases now trash?
« Reply #25 on: December 26, 2008, 08:12:30 PM »
P.S Use a rubber mat for bottom of tub, don't ask me how I know ???
Yep!!!!!!!!
I put some gnarly black lines on our tub.  I freaked out before my wife got home from travels, but luckily, it polished out with some abrasive cleaner.
I put some cardboard underneath for the second go.
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
« Reply #26 on: December 27, 2008, 12:29:22 AM »
Geez, you guys are ballsier than I thought, I didn't clean mine in the bath tub, I bought a cheap plastic tub from my local hardware store (great for storing parts too) and cleaned them out in the garage............  ::)
It's the trisodium phosphate in dishwashing detergent that does not like aluminum.
What are you doing spouting proper chemical names like that Jerry? I would have thought that this time of year you'd be sipping makers like me, and mumbling incoherently...............  ;D
Offline Brantley
  • Drano
« Reply #27 on: December 27, 2008, 02:35:06 AM »
The only problem I've seen is staining of the bare aluminum with the automotive washers/detergents. I'd be very careful putting those in any washing machine. If you are painting them no big deal.
The whole point of this debacle was to blast the PAINTED surfaces since I was having a repair done. Had I not needed a weld I'd have poured old dot 3  brake fluid on the sucker and let the old paint bubble off, wash it, and repaint. I actually thought I should only use the water pressure from the washer of which I spoke as I am the cat what repairs it when it acts up. (i.e. I can disconnect the lines that supply the detergent that BURRRRRNS pale skin, the rinse agent, and the sanitiser and maybe just pour a bit of Dawn in) And Terry- one thing I haven't figured out how to destroy is an 100 yr old clawfoot tub- although it's been tried.
