Author Topic: Where to get torque wrench calibrated?  (Read 2109 times)
Offline OakBehringer
« on: December 28, 2008, 07:15:42 pm »
I have a clicky type torque wrench that is a few years old that I would like to have calibrated before I start reassembling my 350F engine. Where can/should I have this done?
Thanks!
Adam
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Re: Where to get torque wrench calibrated?
« Reply #1 on: December 28, 2008, 08:09:24 pm »
snap-On truck.
« Reply #2 on: December 28, 2008, 08:35:02 pm »
Aside from driving around aimlessly, how can I find a SnapOn truck?
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline Really?
« Reply #3 on: December 28, 2008, 09:34:06 pm »
Tried to see if I could locate one from the snap-on site but it won't unless you are a professional in the trade, not someone at the house.
You might stop by a local car/bike dealer or a local shop and ask when the snap-on guy comes by, then show up.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
« Reply #4 on: December 29, 2008, 07:56:10 am »
Do it yourself with a postal spring balance (or any other that is accurate0 and some string.
Clamp the square drive in the vice and measure exactly 1 foot (12 inches) from the middle of the square and attach your string there.
Attach spring balance and pull till wrench clicks
Poundage on balance should be same as setting on wrench
DONT FORGET
Most torque wrenches are only +or- 10%
Expensive ones are +or- 5%
Snap on torque meters +or- 2%
« Reply #5 on: December 29, 2008, 10:24:48 am »
Snap-on might be in the phone book, or most body shop guys will have his card , unless they are Mac guys.
Also, any large industrial plants nearby?? Their Quality Control dept may have a tester.
 Also tool repair guys that repair electric and pneumatic tools, they may have one..
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: December 30, 2008, 01:02:06 am »
Adam,
I can help you.  PM sent.
mystic_1
- John Augustus Shedd
« Reply #7 on: December 30, 2008, 07:26:58 am »
Dont EVER clamp a square drive from a torque wrench in a vise  :o to try it..
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #8 on: December 30, 2008, 10:40:22 am »
 ??? explain, I have done the same as bryanj many times to check a torque wrench, obviously you stop pulling when the wrench clicks else you could bend the shaft, but if that needed explaining I don't belive you should be using a torque wrench anyway.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
« Reply #9 on: December 30, 2008, 10:49:54 am »
It is really hard on it, the smaller the size the harder you clamp, to keep it from moving.. think 3/8 or 1/4 inch. If it has a ball detent in it there is a chance you can deform the square part.
So if you must play with it sacrifice a socket or an extension, they are not calibrated and are much cheaper.
« Last Edit: December 30, 2008, 10:45:01 pm by 754 »
« Reply #10 on: December 30, 2008, 08:24:16 pm »
Never had to tighten one that hard
