Author Topic: DIY Egli Sohc 4  (Read 143349 times)
Re: DIY Egli Sohc 4
« Reply #225 on: May 03, 2009, 09:23:21 PM »
Mec, are you milling them out of 7075?
Offline mec
Re: DIY Egli Sohc 4
« Reply #226 on: May 03, 2009, 11:50:41 PM »
yes, the rear sprockets are from Al 7075
and no, buying from a supplier costs less considering the costs of the material and the wear of the mill and cutting tools. three hours of work in addition.....
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline Flying J
Re: DIY Egli Sohc 4
« Reply #227 on: May 09, 2009, 10:45:36 PM »
only place i could think to post this
Offline Soos
Re: DIY Egli Sohc 4
« Reply #228 on: May 10, 2009, 07:09:32 AM »
I wanna take that out on the salt flats!!!
I bet it would do well with the full fairing.
Still a amazing sight to look at your bike Mec.
If I ever do any more world traveling, i'm stopping in Germany to get a glimpse of your bike!!
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
Re: DIY Egli Sohc 4
« Reply #229 on: May 10, 2009, 02:20:49 PM »
Take some binoculars then he lives in Austria  ;D
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: DIY Egli Sohc 4
« Reply #230 on: May 17, 2009, 11:14:26 PM »
hahahahahaha I thought he was in germany also !!!
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Soos
Re: DIY Egli Sohc 4
« Reply #231 on: May 17, 2009, 11:28:37 PM »
hahaha....
-=≡ Soos ≡=-
Offline Ecosse
  • Member #4139
    • My 550 walk around video
Re: DIY Egli Sohc 4
« Reply #232 on: May 17, 2009, 11:36:41 PM »
i can picture mec rolling his eyes and smacking his forehead.  ;D
1974 CB550K
                                  Your 1%er name
Offline mec
Re: DIY Egli Sohc 4
« Reply #233 on: May 18, 2009, 02:21:51 AM »
i am happy when there is one or the other who knows that we in austria do not have any kangaroos  ;)
austria vs germany: there is not much difference exept germany is 5(?) times larger.
as far as i know, this bike is the result of a collaboration between colani and f.w.egli, trying to brake the 300km/h barriere. however, the fairing was not working, it was too dangerous to go high speeds lightening the front wheel and resulting in too much sidewind sensitiveness.
the record braking run was done with a "half fairing", the bike did one run over 330km/h, with an average speed of 272km/h which was a milestone these days.
engine was a turbo blown kawa Z 1000 motor, 280 rear wheel HP.
colani and egli ended the collaboration at the judges, however.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
Re: DIY Egli Sohc 4
« Reply #234 on: May 18, 2009, 08:56:52 AM »
Where did all of the kangaroos go?  Did they go extinct?  What about the koalas and the rabbits?  ;D ;D ;D ;D ;D ;D ;D ;D
333:  Think "Shakeweight".
Offline mec
Re: DIY Egli Sohc 4
« Reply #235 on: June 15, 2009, 06:15:59 AM »
hello,
good and bad news:
last weekend I had been in schleiz competing in the "classic open" class. it was the first time i had been at the racetrack schleiz. here is a onboard video from a unknown guy with his K5: http://www.rennstrecken.tv/strecke/schleizer-dreieck/  (klick onboard suzuki K5).
my bike did well. handling was excellent, nothing to worry about and no wish to improve anything. the engine is a killer. in combination with the light weight of the bike my egli performed well, there had been more than one guy, wondering about the speed of this vintage racer.
we had to do 5x 20min practice sessions. at the end of the third session my engine stopped without any warnings. no metallic noise however, i thought the dyna S refused to do their job.
back in the paddock, it took 10 minutes to see that the camshaft didnt turn. obviously the heavy duty camchain broke. end of the weekend.
now at thome, the engine is disassemled, i saw that the camshaft broke where there are the threads to fasten the camchain sprocket. the missing piece of steel came between the chain and the crankshaft sprocket to brake the chain. fortunately there is no damage visible to the crankshaft. no damage to the pistons either. 2 inValves bent, 2exValves bent, a new chamchain and a new camshaft and the engine will be alive again.
this means, that i will not be able to travel with my eglireplika to Spa the coming weekend. instead i will come with our road racing guzzi.
mec
« Last Edit: June 15, 2009, 06:36:28 AM by mec »
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline Frankencake
  • Yesssssss,
Re: DIY Egli Sohc 4
« Reply #236 on: June 15, 2009, 06:27:47 AM »
That is too sad to hear.  The good thing is that it wasn't worse like having the rear tire lock up on you in a corner.  A floating piece of steel in an engine can play havoc.  It is also sad that you'll have ti ride the Guzzi ;D ;D ;D
Offline Ecosse
  • Member #4139
Re: DIY Egli Sohc 4
« Reply #237 on: June 15, 2009, 07:10:51 AM »
sorry to hear of it mec. but, as 78ss says, it's good it wasn't worse.
none the less this must be a disappointment. bring back pix of spa!
btw: i must have jinxed you; just this weekend i was wondering how your were doing with your egli-rep.  :-\
1974 CB550K
                                  Your 1%er name
Offline mec
Re: DIY Egli Sohc 4
« Reply #238 on: June 15, 2009, 12:34:37 PM »
because i did not have a spare cylinder base gasket, i modified a stock one to fit the 1000ccm sleeves. this was easy to do with the small cnc mill.
i have a worn stock camshaft, cut one of the mounting brackets with a saw and did some "repair TIG weldings". on to the lathe, a little grinding and soon the camshaft looked as a new one. only the hole and the M7 thread will to be machined (last picture, extra long drills).
i will try this fix with the webcam too, but i think this cam will end as a spare one, maybe will be used in a cheaper engine again.
where is a will, there is a way.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline my78k
Re: DIY Egli Sohc 4
« Reply #239 on: June 15, 2009, 12:52:22 PM »
Where there is a will (all the right and expensive tools and a hell of a lot of skill) there is a way!  ;)
Dennis
Offline Ecosse
  • Member #4139
Re: DIY Egli Sohc 4
« Reply #240 on: June 15, 2009, 01:09:44 PM »
Dennis
:D :D
1974 CB550K
                                  Your 1%er name
Re: DIY Egli Sohc 4
« Reply #241 on: June 15, 2009, 11:43:39 PM »
Sorry to hear of your problem but now we can watch as you do more  ;)
I noticed 241 on the K5 speedo. Assuming KPH. Was that when you were about to pass him? Thats 150mph in our language. Don't think you'll get 14K rpm but 241KPH could very well happen. Take it easy on those fancy new bikes.
Offline turboguzzi
Re: DIY Egli Sohc 4
« Reply #242 on: June 17, 2009, 12:29:11 AM »
Hi MEC, sorry to hear about your jinxed track day,
looks like a very rare failure to me..... any chance that you were over tightening that bolt?
If you got away from a cam failure with just a few bent valves, count yourself lucky!
Jerry, dont think that even Valentino Rossi with a on a kitted CB750 would be able to keep up with a well ridden 160rwhp GSXR1000 K5 , even with a big bore motor and 113rwhp  ;)
TG
Re: DIY Egli Sohc 4
« Reply #243 on: June 18, 2009, 04:28:21 AM »
G'Day Mec, beautiful work as usual, did you work out how the tab broke on the camshaft? Anything to do with the slotted sprocket? Also, can you take a pic of your camchain adjuster mate? It looks very interesting..................  ;D
Offline mec
Re: DIY Egli Sohc 4
« Reply #244 on: June 22, 2009, 10:24:51 AM »
back from Spa, and very tired.....
first impressions: guzzi, guzzi, guzzi.
never seen as much moto guzzis going that fast. weather, sunny, rainy, warm and cold.
back to my engine: there are two points i realized disassembling the engine. engine has a K2 head, cam chain sprocket seems to be from a F2, as both 7mm screws seem to be from a F2. i do have two versions of these 7mm screws: one pair is 11mm long, the other one is 12mm and is shouldered. in my engine i had the 12mm.
the camshaft does have axial play. you will find a position where the camshaft rotates free. pushing the camshaft to the other side,the thread of the screws touched the head and milled a very small amount of aluminium from the head (this spot can be seen near the round rubber sealing of cyl 2). this continuous load may have caused the failure.
second, my self made slots in the cam sprocket are a little bit too long, more than necessary. this puts unnecessary loads to the threads of the cam tab.
now i have shortened the 12mm screws, cause i will go for the shouldered ones.
4 pics from spa 2009
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline HavocTurbo
  • Can you tell?
Re: DIY Egli Sohc 4
« Reply #245 on: June 22, 2009, 10:30:02 AM »
Ecosse catch me I'm faint....
I'm in LOVE with #2
09 XL883L - No Name
Offline Ecosse
  • Member #4139
Re: DIY Egli Sohc 4
« Reply #246 on: June 22, 2009, 10:38:08 AM »
I'm in LOVE with #2
:D!   i just tuned in before you posted and was speechless. i've never seen that bike sans clothing. moto porn indeed.
mec, i'm glad you seemed to have solved this mystery and appreciate your continued documentation of my dream bike. again, i'm glad the damage was not worse. oh yeah... thanks for the spa pix.
1974 CB550K
                                  Your 1%er name
Offline mec
Re: DIY Egli Sohc 4
« Reply #247 on: June 22, 2009, 10:50:03 AM »
yes, the elf-honda is heaven.
i have seen this bike in the 80ies(?) racing the endurance championship in austria. driver? maybe ron haslam, raymond roche?
however the bike did not win, it was always good for third place (competing against all the factory bikes!).
i was happy to see this technical wonder again (however static display).
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline HavocTurbo
  • Can you tell?
Re: DIY Egli Sohc 4
« Reply #248 on: June 22, 2009, 10:55:29 AM »
You don't have any more nekkid pics of it do you?  :-[  :D
09 XL883L - No Name
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: DIY Egli Sohc 4
« Reply #249 on: June 22, 2009, 10:57:42 AM »
Me too (back from Spa and knackered...)
I looked all over the pit lane and garages but couldn't find Bike #50...  :(
I too saw that Honda  ;D
I have never seen so many MVs
Here's me and Phil Read on his 1974 Championship winning MV 500
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
