mec- I have more then one metallurgist friend, and quite a few friends at Litespeed, one of the largest Ti users/ builders in the world. If you have any queries LMK and I will pass them on.
thank you for your help.
projekt update:
last weekend was the first roll out. surprisingly all went fine.
we visited the Euroring in Hungary. a small race track with ~14 more or less tight turns, max speed approx 140km/h at the short straight.
three fellows and me, 6 bikes: 500cm rotax enduro, kawasaki 500 twin, suzuki gsxr 1100, moto guzzi lemans 850 (with 98rwHP!), duc hypermotard and my egli honda).
some comments on my egli:
after the first corners it was obvious that the bike is unbelieveable willing to corner. i had to familiarize with this behaviour and found that there are some similarities with the hypermotard. unfortunately after two laps i had to come in the pits because the gear lever was blocked and it was not possible to change gears any more. what a bad surprise! it was late in the afternoon and I decided to do some laps on the hypermotard.
in the evening i fixed the problem with the gear lever. the cause was a loose 6mm bolt in the gear change mechanism behind the gear cover, blocking the inner part of the gear change shaft.
the next day another problem occured: activating the front brake, the front light turned on
i did not waste my time to solve this issue.
lap after lap i began to have more and more confidence in the bike. the brakes started to work, no wonder with the very new brake pads.
the rest of the story is short: the bike handles very well, brakes are a pleasure (2 lockheeds and 315mm disks cannot fail), surprisingly the front fork worked fine as did the rear shocks. there was no need to change any settings (except the gearing, I used a 17er sprocket and 48teeth at the rear).
the engine worked fantastic. much, very much low end power and power all the way from 3000rpm till rev limiter at 9500rpm. but, as I remember, I run once in the rev limit, and that was because i wanted to look if the engine works at high rpms as well.
the bad side of the adventure: the rider had severe problems, yes me. it seems that I suffer something like a "sea sickness" or "motion sickness". hard accelerating or braking makes me feel like %$(&. even the next day i feel some dizziness. I am curoius if I will find help.
sorry for the bad quality of the pics.
mec
