hi TG,
thanks for your input. sure your argumentation is correct. but i am riding my racebikes that way (reversed shifting with "incorrect arc movement") for many years now without complaints. the old cb750 transmission can not be compared to new transmissions however, especially 4th gear is a trouble shooter, but concentrating during shifting helps, ditto slower (millisecond range
shifting as well.
the next point is, that i am a "light weight maniac". as mentioned in another post, i prefere 10kg less over 10 hp more.
@ all:
some weeks ago we raced at the "slovakiaring". unfortunately we had two days at a "shortened track", ~3.5km. a complete lap is 7km long. there are 5 or more possibilities to change the track layout, i dont know why, but we had to be content with a short one. either way, we had fun, the track makes joy to ride.
i did one session, recognizing that my shoulder hurts a little bit and there is some lack of power in it. all other sessions a friend of mine, robert, rode the bike.
klaus, rider of our "eau rouge guzzi" was happy finishing fourth in the race held on sunday. both bikes had our Stealth GPS laptimer onboard. this is a little device that makes joy to play with.
what makes me not so happy, was the fact that our guzzi reached 221km/h topspeed, compaired to 211km/h to my sohc. my honda was geared way too long, 17:42, however. fifth gear was fine at the end of the start/finish line. but i am skeptical, if a proper gearing would have helped to beat the guzzi. maybe i will do another dynorun, and look if there is something wrong with the engine. 27/28/29 sept we will compete at the GTF event in Rijeka, on thursday travelling to Imola and start at the 200 Miglia di Imola Revival (
http://de.200miglia.com/). we hope that the bikes will be in one piece after rijeka. our guzzi will be raced not only in the short runs, but also in a 2 hours race in rijeka.
some words to our laptimer graphs from slovakiaring (all data can be saved via blue tooth to your laptop):
the picture titled "robert" is my sohc, "klaus" stands for guzzi.
the yellow graph is measured Speed in km/h, x-axis track length in meters.
the violet graph is longitudinal G-loads. you can see braking, accelerating and even shifting.
in the left window we can see all laptimes during this session and below, the track in red (accelerating) and blue (braking). you can put your mouse wherever you want at the track graph and the programm shows the speed at this position of the track. there are much more features (i am unable to understand one or the other) like lateral G-loads, lap by lap comparison a.s.o...
comparing the graphs (guzzi and sohc) at the end of the finish line, fastest point, you can see that the guzzi graph is steeper, more upright. this is a hint that the guzzi is more powerfull, has better acceleration and topspeed. this is a no go, therefore one more dynorun.
mec
