Author Topic: Throttle Grip Adjuster ???  (Read 847 times)
Offline fishman_Phil
« on: January 01, 2009, 08:16:57 PM »
When sorting thru my parts yesterday I came across a switch assembly that had a chrome plated screw under it with a spring, sitting between the push and pull throttle cables.
Checking all my other switches they all have threaded holes under them but no screw. I checked my parts manual out and sure enough they call part number 10 a Throttle Grip Adjuster.
Ouit of curiosity, how many out there actually have this. I presume it was standard even though this is a first for me to see one.
Is it for putting a little tension on the grip for setting the throttle in one place warmups or for maintaining you speed as you wave out to someone? Cheers
1972 Honda CB350F (2); 1975 CB400F; 1983 CBX400F (1); 1962 Suzuki MA50 (1); Suzuki M15 (3); Suzuki M15Mk2 (2); Suzuki M31 (2); 1936 James H12 (2); 1948 Triumph Speed Twin 500; 1989 Suzuki GSXR250F; Yamaha Chappy (2); alot of work yet to be done.
Re: Throttle Grip Adjuster ???
« Reply #1 on: January 01, 2009, 08:38:40 PM »
Yes that's what its for. But US liability fears caused Honda to stop supplying it and I don't think you can buy it. Being a thumbscrew type set up, its not nearly as convenient as commercially available throttle drags like Vista Cruise. I have one of these on all my bikes. Allows to lock a higher idle during warmup, and then a brief relief while I shake the numbness out of my hand,  I wave with my left hand :)  Never lock it for long. A quick flick of the thumb will lock or unlock it. And its not so tight you can't turn the throttle against it while locked.
http://www.aerostich.com/catalog/US/Vista-Cruise-Control-p-17006.html
« Last Edit: January 01, 2009, 08:40:52 PM by MCRider »
« Reply #2 on: January 01, 2009, 08:42:08 PM »
Cheers ... thanks for that. I will add it to the CB350F sidecar project I am working on. All the other switches, although threaded did not show signs on having anything screwed into them, so I dear say they were banned or discontinued here in NZ as well.
« Reply #3 on: January 01, 2009, 08:56:16 PM »
You're welcome. You can find VistaCruise cheaper other places.  I love it.
« Reply #4 on: January 01, 2009, 11:56:49 PM »
There is a thin metal shoe that gets pushed against the plastic throttle sleeve, it is quite often missing.
I did not know that they stopped using the thumbsrew, must have been in use till at least 73 or longer..
« Reply #5 on: January 02, 2009, 12:43:29 AM »
Never stopped in uk
