The F3 carbs were tuned for the breathing characteristics of the F3 engine along with the stock exhaust and air box filter, 28mm venturis.
The earlier carbs were tuned for the breathing characteristics of the K2 engine along with the stock exhaust and air box filter, 28mm venturis.
In either case, you have some carb tuning to do with the new exhaust and different breathing characteristics between the two engines.
I rather prefer the newer PD style carbs as you can set the idle lean and rely on the accelerator pump to get a nice/brisk throttle response. The downside is that the idle screws have limited range (probably not a problem in this application).
And, the throttle valve needles don't have the extra adjustment grooves to fine tune the midrange throttle setting mixtures. (though 77 models do have those grooves). Assuming you need the richen the midrange (unknown requirement), you can shim the F3 needles for some adjustment.
The early carbs rely on a very rich setting at idle to get acceleration throttle response. Still can't snap the throttle wide open from idle without wheezing the motor (unless you REALLY set the idle and midrange slobbery rich). However, the needles are multi grooved for midrange adjustment, and other internal parts are easier to get. And you don't have to worry about making the accelerator pump work properly as you will with the F3 carbs. (it's not that difficult, really.)
I see the earlier carbs as "sloppy" carbs, less finicky in their adjustment settings. The F3 carbs are more precise and give better operation after "dial in". Kinda depends on where your priorities lie. Just making it go, or making it run sweet.
