Author Topic: Tweek bar ?  (Read 6480 times)
Re: Tweek bar ?
« Reply #25 on: March 04, 2012, 09:50:48 PM »
Dive bar.....That should have been glaringly obvious to some of the posters.... ;D ;D :o
Re: Tweek bar ?
« Reply #26 on: March 04, 2012, 09:57:30 PM »
the blue oyster bar?
Re: Tweek bar ?
« Reply #27 on: March 04, 2012, 10:01:20 PM »
Smokey the bar?
Re: Tweek bar ?
« Reply #28 on: March 04, 2012, 10:07:06 PM »
Re: Tweek bar ?
« Reply #29 on: March 04, 2012, 10:15:01 PM »
 grizzly bahr...
Re: Tweek bar ?
« Reply #30 on: March 05, 2012, 01:00:10 AM »
Bar B Q
Offline grcamna2
Re: Tweek bar ?
« Reply #31 on: March 05, 2012, 04:07:20 AM »
Hi All, Will a tweek bar off of a 74 550F also fit a 350F? Is the twin 350 tubes the same as a 350F? Many thanks Tattoo
I know for sure that the CB350F & the CB350 twin use the same diameter fork tubes & the triple tree offset are exactly the same...you can interchange parts from one bike to the other...the CB350F forks may be a different length than the CB350 twin.
The CB550 has 35mm fork tubes w/ different offset & width on the triple tree's;the CB350F & twin both use 33mm fork tubes.
                                      Has anyone heard of "bargumph".., it's Frog-talk ???  ;D
« Last Edit: March 05, 2012, 04:09:18 AM by grcamna2 »
75' CB400F/'bunch o' parts'
Offline cb750-bobber
  • With age, comes character...I support vintage!
Re: Tweek bar ?
« Reply #32 on: April 29, 2012, 04:37:06 AM »
Just read on from my initial post a few mo. back...looks like you guys had fun with the "bar"....lol  Anywhoot, No chrome on my triple trees...Did notice my "sidewall to tread" line is not perfectly "aligned" ..I know there is probably a way to say what I mean but I dont know of it..HAHAHAH So to explain, when your rolling the bike along at 10mph you can see the reveal of the sidewall on the front tire-to-rim changing, as though it is not seated evenly around the bead/rim area..... Going to remove and investigate today...
Offline lucky
Re: Tweek bar ?
« Reply #33 on: April 29, 2012, 03:20:04 PM »
Let's fire this thread back up, I'm hoping 754 knows...I have a stock front end with a cycleX boxer frame..it appears to be raked a little..Which would do me better? a fork brace or a tweek bar? I am suffering from some front end wobble entering any corner where lean is needed. FYI i have NO front fender an a single caliper front brake set-up.thanks in advance.
Many times the wobble is caused by the worn TIRE.
Re: Tweek bar ?
« Reply #34 on: April 29, 2012, 03:51:26 PM »
That poorly seated tire will cause your wobble....
Re: Tweek bar ?
« Reply #35 on: April 29, 2012, 06:11:25 PM »
Thanks guys, thought it would be a problem..didnt get a chance to re-seat it today but it will be fixed/replaced before my next ride...hopefully my "corner-entrance' isnt so shakey anymore:P
Offline Gman
Re: Tweek bar ?
« Reply #36 on: April 29, 2012, 07:07:34 PM »
Wow - what forum are we on?  You all missed... wait for it...
biker bar.   ;D
(Had to read the thread twice just to make sure someone didn't beat me to it.)
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Re: Tweek bar ?
« Reply #37 on: April 29, 2012, 07:14:02 PM »
G-Man=WIN...nice! 8)
Re: Tweek bar ?
« Reply #38 on: April 29, 2012, 08:52:23 PM »
Tequila Bar
