Author Topic: Fork issue  (Read 1186 times)
Offline Bouncer
  • "Bear Down"
Fork issue
« on: January 02, 2009, 06:33:38 PM »
Any tricks to removing the bottom bolt for the fork? 78 750F
I am having one hell of a time trying to get this thing out. I have almost stripped it completely with an allen key, hex key, whatever you would like to call it. I am trying to disassemble my forks. I have used heat as well.... any other suggestions welcome. I may have to get ahold of an air compressor and impact gun with a 1/2" attachment for an allen key socket. The one fork came apart no problem the one I am working on now.... not so much. >:(
New to the game.
1981 CB650C (Finished) Rat Bike
1978 CB750F Project "Bear Down"
Offline 78 k550
Re: Fork issue
« Reply #1 on: January 02, 2009, 06:39:11 PM »
Some times there so stuck you need an impact wrench. I have used my air one at times. If you strip one it will need to be drilled out. just take the head off and the fork will slide down then you can pull the bolt out.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Re: Fork issue
« Reply #2 on: January 02, 2009, 06:51:56 PM »
your talking about the dampener right .
are you holding the inside half while trying to turn it out (broom stick trick)
Offline Bouncer
  • "Bear Down"
Re: Fork issue
« Reply #3 on: January 02, 2009, 06:52:08 PM »
Paul
I was thinking about drilling it out but I would prefer not to. I am thinking about hammering a bigger size allen key socket in there and using an impact driver set on kill....
New to the game.
Offline Bouncer
  • "Bear Down"
Re: Fork issue
« Reply #4 on: January 02, 2009, 06:52:53 PM »
???? broomstick trick you say?
I have not taken the inner spring out yet. So it is not spinning while I turn, just stuck.
New to the game.
Offline 78 k550
Re: Fork issue
« Reply #5 on: January 02, 2009, 08:26:43 PM »
also if you can have someone pull as hard as they can to tighten up the inner tube. But thats only if the bolt is spinning the insides.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Hush
Re: Fork issue
« Reply #6 on: January 03, 2009, 12:22:20 AM »
Don't have a 750 but if all else fails drill a small hole into the side of the bolt and throw a screw into it, this will give your wrench or stilson something to chew on.
Re: Fork issue
« Reply #7 on: January 03, 2009, 12:46:38 AM »
find a broomstick with a tapered end , take the spring out . put the tapered end down in the fork , to brace the dampener
put the stick in a vice or have someone hold it
thats the broomstick trick, but if your stripping the hex key it gotta be seized up
KingCustomCycles.com
Re: Fork issue
« Reply #8 on: January 03, 2009, 04:05:55 AM »
I fashioned a steel rod to replace the broomstick idea.  One end is tapered and the other end has a slot cut in it to mate with the roll pin inside some fork sliders.  I mount it in a vice and have a go.  The steel helps transfer any force I am applying to the allen bolt rather than absorbing it.  Wood is a tremendous dampener.  Forks are a smelly icky job.
Re: Fork issue
« Reply #9 on: January 03, 2009, 10:06:19 AM »
i made a similar contraption , works like a charm... but it works no better then the broomstick i've found it just has a handle
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
Re: Fork issue
« Reply #10 on: January 03, 2009, 01:44:51 PM »
Worked for me!
Used a 5/16" allen wrench IIRC.
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline Patrick
Re: Fork issue
« Reply #11 on: January 03, 2009, 01:53:17 PM »
I cut off an 8mm allen wrench, leaving a long 8mm shaft. I put that into an 8mm socket and put the socket on my impact driver. The bolt was toast, but it came out.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
