I have had good luck cleaning the engine parts with a brush that look like a toothbrush, but with brass bristles, fine steel wool(or brass or copper if youcan find them), fine sandpaper if necessary, flitz or other polish.
Combinations of above + elbow grease work wonders..
Are you asking if the carbs have to come off the rack, to get cleaned or?.. if they look clean try to check the idle jets.
you may have some nasty electrical problems if there was a bolt replacing a fuse, hope not.
You might be able to trade exhaust, but I would try to keep them, I threw out a few sets after I kept them10 + years, now I can NEVER find them around here..
good luck.. what manual are you using? & bag or label your parts as they come off..
