Author Topic: Opinions on Dual Disc Forks?  (Read 2268 times)
Swoop
« on: January 09, 2009, 11:32:18 AM »
A well beaten subject....but did not find what I was looking for.  :'(
I want to put a dual set up on a new cafe I am building and I have the option of early K forks or 75 F forks.
As I see it the early K's (69-72) are good....except they always have that booger rust up between the yokes. ( I have one mint fork tube...but have never seen another and I don't think they are available now)
The F forks (have a pair of these) are alot purdier up top....but I don't have the calipers or hangers and I figure they might be a tad harder to find seeing as they were a comparitively smaller market bike. (750A had them too)
Third option (not too serious) I have a mint 79 front end that I can put a cb450 front hub (drum) (Yes apparently the K wheels don't fit on the 79 fornt end...I tried a mock up)
But the stoppers would probably not be up to the task....but it would look cool  8)
Opinions or any other options ????
The bike is a mid 70's custom cafe CB750.
Thanks
Steve
« Last Edit: January 09, 2009, 11:42:21 AM by Swoop »
Offline gerhed
Re: Opinions on Dual Disc Forks?
« Reply #1 on: January 09, 2009, 01:48:05 PM »
I put dual discs on my '75F--pretty straight forward.
Had to take about a half inch off the collar that drives the speedo.
          83 XL600R in CB360 Frame
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: January 09, 2009, 04:05:06 PM »
Putting dual disc on K0-K2 forks requires a special Unobtanium mirror-image mount for the right-side caliper arm.  Dual discing later forks is way easier.
mystic_1
- John Augustus Shedd
Offline Soos
« Reply #3 on: January 09, 2009, 04:14:50 PM »
I'm running a '79750 dual disk front end(minus rim and tripple trees) on my cb650.
Lined up perfectly.
Probably one of the easiest mods I have done so far.
Definitely worth the stopping power.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: January 09, 2009, 06:39:01 PM »
Mystic hit the nail on the head.... i searched for quite a while for a caliper mount for my 72 for the right side....
never found one.
Although.....Kevin (aka TT400 I think)  has my left side caliper and is machining matching left and right versions.
he is planning on selling them on his website....  might be a while though...
« Reply #5 on: January 10, 2009, 01:24:22 AM »
You can take a standard bracket and shorten a boss thet is too long then space the one that is too short with washers but it dont look as purdy
« Reply #6 on: January 10, 2009, 09:44:14 AM »
I had a buddy? that ran a 72 with duals..cant remember if he modded the stock hanger or biught a kit back then..
If you run 73 -76 forks, you get..
-easier miunting, with cleaner looks
-fork tubes that are hard chromed to the top and dont rust
-are able to change fork seals without removing the whole fork (if you get the allen bolt out).
Way easier to live with, IMO
Re SS forks, I dont like the look either, may trim some ribs, but I am probably going to use them to try to mount radial calipers on..
Offline Soos
« Reply #7 on: January 10, 2009, 04:49:00 PM »
Whats wrong with the "slippery sam" setup?
http://paintingsofbikes.com/sdp406_SlipperySam.html
Anyone know of any drawbacks to this setup?
l8r
-=≡ Soos ≡=-
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #8 on: January 10, 2009, 06:28:15 PM »
am i mistaken, or isn't the front brake setup on the F0 the same as the K2-8? those parts are in abundance.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Jim F
  • go baby go
« Reply #9 on: January 10, 2009, 06:45:12 PM »
Why not go with a 75GL 1000 front end?
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline JLeather
« Reply #10 on: January 10, 2009, 07:27:46 PM »
Why not 77/78F forks?  Don't like the looks?  My current build is gonna be running a set of 'matic spoked alloy rims on a set of '78F forks.  You just gotta space the calipers inwards about 1/4" each side and make an axle.  Haven't got the speedo mount figured out yet though.
KingCustomCycles.com
« Reply #11 on: January 11, 2009, 05:33:04 AM »
+1 on the GL Goldwing set-up.  I love it with the beefier tubes and dual discs.  Cheap too.  The whole triple tree and all slid right into my 74 K model frame.
« Reply #12 on: January 11, 2009, 10:16:23 AM »
1 thing to consider, the 2 F discs weigh less than one CB disc. So no matter how much you drill or thin them you aint ever going to get close to that weight. that may matter to you or not.
« Reply #13 on: January 11, 2009, 10:22:55 AM »
      That's what I did. I used the early wheel/early axle but did a lot of other work. It works nice. ;)
Offline Jim F
  • go baby go
« Reply #14 on: January 12, 2009, 07:44:10 PM »
This is my GL front end with ZX6 calipers and RC51 rotors
but that was alot of work too
especially the hangers
Offline Geeto67
  • A grumpy
« Reply #15 on: January 13, 2009, 03:27:39 AM »
Thanks for the comments guys.
I am pretty sure the 75/76 F caliper and some of the hanger parts are particular to that bike...or the 750A.
I didn't think the 69-72 dual disc was that tricky....but sounds like it may be.
I guess I'll try to get some F parts for the forks....or keep an eye out for a 75/76 wing setup.
Steve
no, the 75-76 F brake parts are the same as the K parts for that year (and previous years up to 1972). The F forks seem to be longer (I have an F and K front end standing next to each other in the garage) but not by much and it could just be that my K front end is worn out. It is 77-78 F brakes that are not interchangible with anything else. On american bikess the front fender is different also but on european F0/f1's it is the same as the K.
Maintenance Matters Most
Offline mick750F
« Reply #16 on: January 13, 2009, 02:23:26 PM »
   Another thing you could consider is this. If you go with 77/78F forks you can mount the later dohc 750/900 dual piston calipers IF you also use the mounting brackets from the same calipers. I'm upgrading my dual disc brakes on my 78F by doing this. This is a direct "bolt on" with Comstars...don't know what mods you'd have to do for spoke wheels.
Mike
Glosta, MA
Offline Ricky_Racer
« Reply #17 on: January 17, 2009, 05:10:27 AM »
Mick, do you happen to know if the '77-78 GL1000 forks will take the same DOHC brake setup as the Late "F" forks? The bracket centers seem to be the same.  Thanks!  RR
