Author Topic: Need to replace chain, want to replace screws on sprocket cover  (Read 799 times)
Offline Hope
  • How did I become an
  • SOHC member since '01
« on: January 18, 2009, 09:48:01 AM »
Santa brought be a chain for my bike, and I want to replace the screws on the sprocket cover with allen bolts.  Has anyone ever bought the allen bolt set from Cycle Recycle for their 550?
If not, what is a good source for the allen head bolts?
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: Need to replace chain, want to replace screws on sprocket cover
« Reply #1 on: January 18, 2009, 12:40:25 PM »
Hardware store...some even have fancy chrome ones too.... :)
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline 333
  • Time for change
« Reply #2 on: January 19, 2009, 06:30:24 AM »
Must be a good hardware store if they have that in metric.  Most don't.  I am not familiar with Cycle Resource, but converting to allen's is cool.  I have bought some from the dealer where I used to work.
Soapbox time.  Please tell me you are doing the sprockets as well.  Chain and sprockets wear at the same rate.  If you do one without the other, it will wear the new part in a fraction of the normal wear time.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #3 on: January 19, 2009, 06:32:49 AM »
Try the FAQs for sources of allen and ss nuts & bolts.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Hope
« Reply #4 on: January 22, 2009, 09:08:48 AM »
Thanks, I emailed Jim.
333,
I guess you should have talked to Santa because he only brought me a chain. ???
eldar
« Reply #5 on: January 22, 2009, 09:10:33 AM »
Most hardware stores now carry metric. You just have to look as they stash them away behind the standard. They are just denying the inevitable.
Offline tbpmusic
« Reply #6 on: January 22, 2009, 09:15:31 AM »
I get all my stuff from these guys - you may not find the exact length, but you'll find something close.
I'm partial to the button head allens, myself - I think the regular allens look sort of Franken-bike.
http://www.boltdepot.com/metric-socket-products.aspx
Bill Lane
Offline Hope
« Reply #7 on: January 22, 2009, 10:07:12 AM »
FYI - for those of you who have switched to the allen heads on your bikes, Sears has a T-handle set marked down from $24.99 to 6.99 in some of their stores (not all of them).  Here's a link to the set that is marked down:  http://www.sears.com/shc/s/p_10153_12605_00942284000P?vName=Tools&sid=I0084400010000100383&aff=Y
I might swing by and get a set even though I have plenty L shaped allen tools.
Quick question: do these allen screws allow you to put as much torque as needed?  I've never used allen screws much and am a little curious.  I don't want to end up with loose or rounded off allens.
« Last Edit: January 22, 2009, 10:09:58 AM by Hope »
eldar
« Reply #8 on: January 22, 2009, 10:16:35 AM »
They can depending on the design of the head. If the head has a lot of metal and the sides of the hex are not thin, you can do a lot of torque.
