Author Topic: Brake piston / pad nylon spacer  (Read 6969 times)
Offline Chris Liston
    • http://christopherliston.com
« on: October 04, 2005, 06:31:07 AM »
How important is the nylon washer that fits between the piston and the pad.  When rebuilding my brakes yesterday I overlooked it and installed everything up.  The bike brakes fine.  I'm going to take it all apart again and install it anyway.  Mr. Honda figured it should be there so I won't mess with that.
Just wondering whats its there for.
Thanks
2008 Triumph Speed Triple Black and NASTY
1976 CB550F Cafe in progress
http://gallery.sohc4.net/main.php?g2_itemId=2402
Online bryanj
Re: Brake piston / pad nylon spacer
« Reply #1 on: October 04, 2005, 06:35:43 AM »
No idea!, best idea i can come up with is to give a bit of cushion and maybee "tillt" to the pad
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: October 04, 2005, 06:44:00 AM »
I thought it was to stop bralke squeal. Never tried one without it though.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Paul
« Reply #3 on: October 04, 2005, 09:25:59 AM »
I'm not entirely sure if it's for brake squeal (I mentioned this before) but my most recent trick was to put IN a nylon spacer (Home made but sufficient). And my brake squeal has now gone from a shreik to nothing.
Then I'm thinking...isn't there a dimple on the back of the brake pad, and iiffff there wasn't a hollow in protruding part of the piston like there is on most, wouldn't the ring spacer keep the dimple from "Rocking" on contact. ???
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
« Reply #4 on: October 04, 2005, 09:45:38 AM »
The Nylon ring may have had mutiple purposes.  Among the others listed here, I once heard the nylon was put in there to soften the brake lever, so it felt more like the front drum brake of old.  The front disk brake was a production inovation at the time.
Personally, I think the most important contribution is to guide the brake puck wear so as to keep it from cocking and jamming in the caliper bore over the life of the brake pad.
bike54
« Reply #5 on: October 04, 2005, 09:49:02 AM »
noise is just vibration in the air the nylon acts as a asober and cuts it down by my understanding
merv :) :)
« Reply #6 on: October 04, 2005, 10:19:12 AM »
After reading some replies it makes sense to have it there but as Paul wrote there is a dimple in the piston and a bad as a protruding area that fits perfect into the piston.  The lever is solid and feels very responsive.  The nylon is probably there to act as a buffer between piston and pad and soften the feel alittle.  I doubt it would hurt not having it there but I'll replace it anyway.  I'll post the before and afters feels.
eldar
« Reply #7 on: October 04, 2005, 10:44:09 AM »
I would say it is for both noise and alignment. I think it may also help protect the piston from damage as the nylon would absorb harder shocks THAT MAY occur. None of us function as brakes so we do not know what types of shocks they might take. I would rather keep my piston in good shape than have to replace it. Damn things are expensive!
« Reply #8 on: October 04, 2005, 01:46:12 PM »
Eldar, I here that.  This piston is brand new and want it to last.
eldar
« Reply #9 on: October 04, 2005, 01:57:33 PM »
$50 for a some piston on ebay, hate to see what the dealer gouges a person for!
« Reply #10 on: October 04, 2005, 02:43:37 PM »
Try $80 US.   I got mine for around 25pound UK from David Silver.  still made out under dealer costs with piston seal and shipping.  saved about 30 bucks.
Offline 78 k550
« Reply #11 on: October 04, 2005, 05:41:34 PM »
I havent had one apart. If there is metal to metal without the nylon it could were out the piston some how or do other damage.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #12 on: October 04, 2005, 07:01:36 PM »
Been following this post. Is this part unique to the 550? Where exactly is it??
Offline mick750F
« Reply #13 on: October 04, 2005, 07:14:53 PM »
  Bob, this has nothing to do with carburetors. Are you sure you're in the right post? ??? ;D ;D ;D
Mike
Glosta, MA
« Reply #14 on: October 04, 2005, 07:15:44 PM »
Its a nylon/plastic washer about 1/8" thick that sits between the caliper piston and pad.
piston / spacer / pad
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #15 on: October 04, 2005, 07:19:14 PM »
Nah, just curious. On the 750, at least earlier ones, there's just a floating metal cap between the pad and the piston.
Offline mick750F
« Reply #16 on: October 04, 2005, 07:35:33 PM »
   Nothing like it on the '78 750F either...
Mike
Glosta, MA
eldar
« Reply #17 on: October 04, 2005, 10:00:48 PM »
I have a nylon ring on my 750 78K
Online bryanj
« Reply #18 on: October 05, 2005, 01:05:46 AM »
From memory ALL the disc brakes had that nylon washer but as soon as the caliper was split it got lost Rather like the steel waser between the spring and oil filter!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #19 on: October 05, 2005, 02:10:44 AM »
Don't think so. I thought perhaps the same thing re: my 750, so I checked the parts list and diagrams. No nylon washer, just the floating metal cap I described. Not sure why the design diff, but there is one between the models on this score.
Offline dusterdude
« Reply #20 on: October 05, 2005, 06:26:15 AM »
mine also has the metal cap.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
eldar
« Reply #21 on: October 05, 2005, 07:53:20 AM »
Probably was redone in later models.
Offline Jonesy
  • Shop Rat
« Reply #22 on: October 05, 2005, 03:08:55 PM »
The CB360 also uses the nylon washer. A new one was included in the brake pad kit.
« Reply #23 on: October 05, 2005, 04:21:27 PM »
Well,  I reinstalled the nylon washer tonight after work and it is there to soften the lever feel.  Probably really there so the piston and pad don't make direct contact but the lever is definetely much softer feeling.  Feels like I need to bleed the system again.  I much preferred it not being there as far as feel goes.  Bike still stops great with the new pads and rotor though.
Chris
Online bryanj
« Reply #24 on: October 07, 2005, 02:30:00 AM »
OK the 500/550 parts book dont even show the thing and whilst you can see it in the 350/400 there is no part number same as 750F. Its shown as a seperate part in CB750K0-4 and whilst the picture shows it shaped i am certain the UK K2 (which was all we had till the K7) had a nylon washer same as 500. As I remember it the only way to get one was with a genuine honda pad kit, all the aftermarket ones you had to transfer the original
