Author Topic: front brake master cylinder Q's  (Read 900 times)
Offline killersoundz
« on: July 04, 2012, 05:24:12 PM »
The piston in the brake master cylinder I have doesn't appear to be going back in. I pulled the drain bolt out and trying to push it in it's not going anywhere. Looks a little rusty in there too when I took the brake pad out. It needs to go back in to be able to install it on the rotor. Probably needs a rebuild kit maybe eh? I do have a cleaner looking piston here
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
Re: front brake master cylinder Q's
« Reply #1 on: July 04, 2012, 05:49:49 PM »
point of order: the master cylinder is on the handlebar. Do you mean the piston in the caliper? At rotor level?
Everything mustbe clean and shiny to ensure function. Yes you should be able to push the piston (via the pad) into the caliper, if the bleeder is turned open or removed.
Not really a kit for the caliper. Disassemble, clean everything, replace the square section ORing (it does the lions work of retracting the piston).
rebuild kits available for the master cylinder.
Offline BeSeeingYou
« Reply #2 on: July 04, 2012, 06:21:54 PM »
Spend the $6 for the new O ring.  You need to clean the seal groove too and check the condition of the piston.  Some small pitting is common and may not be a problem but at some point it becomes unusable.  How bad is bad....a picture would help.
