Author Topic: CB750 K0 Rear Wheel Offset  (Read 2278 times)
Offline markb
  • When I finish my current project I might be a
« on: January 24, 2009, 02:27:18 PM »
This might be opening a old can of worms but I searched the old threads and didn't find a good answer.  Is the rim on a CB750 K0 supposed to be offset to the hub?  I measured mine and from the rim to the spoke flanges on the hub it is offset 3-4mm (1/8"-3/16") towards the sprocket side of the hub.  This has caused the spokes to dig into the flange on the opposite side.  This wheel has never been apart.  I saw discussions about the whole wheel being offset by about that amount between the swingarm.  Is this the same thing?  It sounded more like that would be accomplished with the spacers on the axle.  It doesn't seem right to me that the hub should be offset to the rim.  Any thoughts?
Thanks,
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline 736cc
Re: CB750 K0 Rear Wheel Offset
« Reply #1 on: January 24, 2009, 06:01:51 PM »
The post K0 front hubs have a quirky offset, not the rear
Offline markb
« Reply #2 on: January 25, 2009, 08:43:27 AM »
I measured my front wheel too and it was right on center.  Did a front wheel offset search and didn't find a good answer either.  Is there a specific post you're referring to?
« Reply #3 on: January 25, 2009, 08:48:21 AM »
Working purely from memory with no objective backup...
The front rim and hub have no offset. I've laced and trued many front wheels. But...
one disk is closer to the centerline than the other, if you have duals, hence the quirkiness. But there is nothing to be done about it.
OCICBW
« Last Edit: January 25, 2009, 09:02:24 AM by MCRider »
