Tom -
Please don't get defensive - in your first post you specifically asked for jetting advice,
Again, you have to judge the jetting from the appearance of the plugs.
I had a couple of 450's when I moved to the Chicago area from Denver, didn't have to touch the jetting at all.
With my latest 450, I went to foam filters and much less restrictive mufflers, and I'm still running the original 130 jets.
They're very forgiving carbs.
And there are other things going on besides jetting - get a good compression reading first. If you don't have a gauge, maybe borrow one, or even get a shop to do it for a couple of bucks - even auto shops can do it for you. Honda draws the "line in the sand" at 164 pounds on a 450.
It's just a matter of gathering the basic diagnostic info before you start to change things up.
Use this method and get a plug "reading" - then go here and interpret what you see -
http://www.4secondsflat.com/plug_chart.htmlPut in clean plugs, then take off and get on it hard for a few miles. Chop the engine, pull off the road and yank the plugs out - compare them to the chart.
Bad rings or valves (detectable by low compression) can cause blackened spark plugs, too.
timing that's not spot on can also cause "dirty" looking plugs.
