Author Topic: Rear set question..  (Read 1295 times)
Offline pddpimp
Rear set question..
« on: January 25, 2009, 04:31:52 PM »
Do they use bushings, bearings, or do they let them ride on the pivot points of the brake and shift lever?
See photo below...
When the majority of the United States population get to be 70 years old, they will finally realize what is really important. And by then it'll be too late.
-'77 CB750 Cafe/Muscle bike (early clone)
Soon to have a hopped up 836cc *sold*
-'75 CB750 with a little bit of character
Offline CrisPDuk
  • Christ on a bike! Me, an
Re: Rear set question..
« Reply #1 on: January 25, 2009, 05:10:59 PM »
I can't speak for these specifically, but the Hayabusa ones that my 550 is running have the aluminium levers pivoting directly upon a steel pin, which in turn is screwed into the bracket.
Hope that helps
1978 CB550 K3
1985 H100S
Offline Steve F
« Reply #2 on: January 25, 2009, 05:47:03 PM »
Again, I don't know about those, but I made my own rearsets, and made oilite bronze bushings for them.  I take them apart every year to clean and grease them up.
fuzzybutt
« Reply #3 on: January 25, 2009, 05:52:58 PM »
i had rask rearsets and they did just have the bare aluminum rotating on a steel pin.
« Reply #4 on: January 25, 2009, 06:00:58 PM »
What model bike are these ones made for?, i can't find them on their site. Never mind , found them.. ::)
« Last Edit: January 25, 2009, 06:30:35 PM by retro rocket »
Offline babyfood1217
  • The only way to drink espresso is as a
  • I miss my baby...
« Reply #5 on: January 25, 2009, 06:14:41 PM »
Alot of the aftermarket levers (shifter and brake) come with a pressed in bushing.  I'll assume bronze, but could be some other material.  I did however read about (can't remember if it was this forum or elsewhere) a rearset that used a needle bearing setup (or something to that effect.)  I'll see if I can dig that up...
-C
I need help moving my project bike from Wisconsin to Seattle, WA.  Willing to pay well.  Contact if interested.
SOHC member: #438
Project: 1976 CB750K
GSXR forks, Monoshock Rear end, 836 in progress, RC51 pipes, custom frame and everything else.
Offline pddpimp
« Reply #6 on: January 25, 2009, 06:16:47 PM »
I plan on making my own.
Thanks for the info guys.
 ;D
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #7 on: January 25, 2009, 06:30:20 PM »
I did too and used Delrin for the bushings.
It is easy to machine and has bearing qualities to it.
What bike are you building rear sets for?
FJ
Offline pddpimp
« Reply #8 on: January 25, 2009, 06:50:06 PM »
'77 CB750K
