Author Topic: popping  (Read 1597 times)
hondafour?
popping
« on: October 05, 2005, 05:26:31 PM »
I just got my '77' cb550k running. I put new floats and carb gaskets in. I cleaned all jets and passages in the carbs. It pops out of #2 cylinder a little at idle, but alot when you are decelerating. Accelerating and cruising is good. I've swapped spark plugs, and checked the valve adjustment, points, timing. Seems to be a carb thing, but I had them apart and I checked them out a couple times. Any deas?
Also what is the stock jetting?  thanks
Offline Lumbee
    • My pics...
Re: popping
« Reply #1 on: October 05, 2005, 05:31:02 PM »
...I'd say its an exhaust leak...specially since u said it pops on deceleration.  Check out the number two pipe good...good for any leaks/holes, especially around where the pipe meets the head...
"I'm not a welder, but I play one on HondaChopper.com"
Offline Bob Wessner
  • "Carbs Suck!"
Re: popping
« Reply #2 on: October 05, 2005, 05:34:03 PM »
If you check that out and it appears not to be the cause, I would then do some plug reading, particularly some low speed, around town riding. The idle mixture could be on the rich side. I had this problem and leaned out the idle mixture some and the popping was virtually eliminated.
Buffo
Re: popping
« Reply #3 on: October 05, 2005, 05:58:24 PM »
I think a "Popping" post should be put in the FAQ section.
there seam to be a lot of Popping question as of late.
hondafour?
Re: popping
« Reply #4 on: October 05, 2005, 06:11:09 PM »
I found the jet specs in the FAQ section
thanks
ejand22
Re: popping
« Reply #5 on: October 05, 2005, 08:54:04 PM »
My number 1 cylinder backfires a bit on deceleration and sometimes at idle, but is fine during aceleration and cruising just like yours.  It makes what could be called a 'popping' sound (not loud).  Maybe that's what you are experiencing.  I've riched up my idle a bit more than normal and I'm guessing the 'popping' is caused by that.
eldar
Re: popping
« Reply #6 on: October 05, 2005, 09:00:15 PM »
a good dwell/tach meter can really help with this. Allows you to tune as accurately as possible. Bad thing is that even usedit can cost $20 or more but I suppose that is nothing in the face of good performance.
