Author Topic: brake pads for my k-4 and unknown caliper year.  (Read 1482 times)
fuzzybutt
« on: January 29, 2009, 09:47:35 PM »
the caliper i've been running on the k4 was from a 75 750f it had a larger piston, however, the caliper when i pulled it apart to rebuild, the bore was in terrible shape, very pitted and scored. so........... i'm putting a k model caliper on, got a new piston and seal kit, new speed bleeder as well. the only thing i need now are brake pads. this caliper doesnt look like my other (also destroyed) k model caliper though. it has the same size bore and bleeder screw as well but the way the pads go in is different. with the destroyed k model caliper theres a slot where a screw in the pad rides but with this one theres a stress fit pin in the top of the bore . what IS this caliper from and does anyone maybe know where i can get the pads for it.
Re: brake pads for my k-4 and unknown caliper year.
« Reply #1 on: January 30, 2009, 04:58:50 AM »
Which way round bot the two bolts go and what heads are on them?
fuzzybutt
« Reply #2 on: January 30, 2009, 06:24:24 AM »
the bolts go from the outside of the fluid filled part of the caliper and thread into the backside. theyre 13 mm hex bolts. 8mm thread size
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #3 on: January 30, 2009, 06:43:22 AM »
If there was a picture of the other side of the caliper, it may help. I'm thinking it's a 550 caliper. If its similar to appearance as the F caliper you've been running, except the bolt spacing is different then its off of a 550.
If you were running the entire 750F brake assembly, you'll need the K brake arm and caliper to convert back to the latter caliper. The F and the K arms are different in thickness, so you cant use the "K" caliper on the "F" arm, and vice versa....
Hope this helps!
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
fuzzybutt
« Reply #4 on: January 30, 2009, 06:53:40 AM »
not only is the spacing different on the arm but the piston in the one i was using is about 4 or 5 mm larger. i do have the arm and all related stuff for it. more pics
Offline cafe750
« Reply #5 on: January 30, 2009, 06:57:27 AM »
That'd be a CB550 caliper....
Roy, Washington
fuzzybutt
« Reply #6 on: January 30, 2009, 06:59:44 AM »
ahhhhhh ok. i THINK this is the one that was originally on the k6 750 i got 4 years ago. piston is the same size as in the 750 and the speed bleeder for the 750 works too. are the thicknesses of the arms also compatible with a 750 rotor? i hope?
« Reply #7 on: January 31, 2009, 03:25:55 AM »
From memory thats the later 750 caliper from sometime after K4 till F1 and should use the same pads as the 500/550
fuzzybutt
« Reply #8 on: January 31, 2009, 07:05:09 AM »
ah so this might be the original k6 caliper then. cool
Offline cafe750
« Reply #9 on: January 31, 2009, 12:05:03 PM »
I do know one thing, the late cb750 caliper and the cb550 caliper look verrry similar, but the 550 has narrower bolt spacing than the 750's calipers do...
Roy, Washington
fuzzybutt
« Reply #10 on: January 31, 2009, 12:09:42 PM »
this one has different bolt spacing from the 75 750f caliper that came off of the mootorcycle, around 8mm or so difference.
Offline Clyde
« Reply #11 on: February 01, 2009, 05:22:14 PM »
I think that it is a 500/550 caliper. They use the same seal as the 750K(0-6), but look like a750F caliper. However I am not an expert on the 500/550 calipers
The 750K caliper changed in 77 when the K7 and then the K8, used the same caliper as the 75F/76F1. The F/F1/K7/K8 caliper uses a bigger piston/seal and different pads (~42mm versus ~38mm for the early . They have a 10mm hex headed bolt screwing in from the outside.
The early 750K caliper (apart from a change of colour) remained the same up to 76. The bolts go in from the inside and use an allen/socket head 10mm bolt.
With your forks, I would try to get another F/K7 caliper if you want slightly better braking. If you want originality look for a K3-K6 caliper (AND ARM as the thickness of the arm is differnt to the F)
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
fuzzybutt
« Reply #12 on: February 01, 2009, 05:48:20 PM »
well, this is a "bitsa" motorcycle. i call it my k4 because the frame is a 1974 model that i got from Jacks Cycle and Salvage in sanford Florida. the motor is a k6 front end unknown year but between a k3 and a k6, rear wheel is a k6 front wheel is a 75 750f.
« Reply #13 on: February 01, 2009, 10:54:44 PM »
When i looked up the pads for the f1 the part came out the same as 360 which i know is the same size as the 500/550. Perhaps the material is different, i dont know, but they will physically fit
