I guess my question is more around the disconnecting of the wiring from the turn signal if I should just splice them back together or if there is an easier, quick disconnect that I might just not be seeing, I have a '72 CB 350 and the wiring is soldered to the connection points so I am just contemplating the best move might be to just cut the wires like an inch down from there and then pull them out, swap the bars and then splice back together. Any thoughts?
