Author Topic: would there be a benefit to having more ignition advance then stock?  (Read 916 times)
Offline pampadori
  • slingshotcycles.com
    • Slingshot Cycles
I'm not sure how many degrees advance the stock spring loaded advance plate gives my CB750.  Doesn't really look like much.  My question is, would there be an increase in power anywhere in the powerband on a Cb750 if the mechancial advance plate was modified to give more advance then what it does from the factory?
www.slingshotcycles.com
brake hoses and more!
SOHC4 is your coupon code for 15% off!
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: would there be a benefit to having more ignition advance then stock?
« Reply #1 on: February 03, 2009, 12:56:10 PM »
Modified, sure- stock, I don't think so.
Unless you are using something other than 87 octane in your 750.
« Last Edit: February 03, 2009, 01:11:19 PM by Dukiedook »
Offline pampadori
    • Slingshot Cycles
« Reply #2 on: February 03, 2009, 05:07:05 PM »
this forum moves too fast! a couple hours go by and there are 25 threads  in frint of this one!
well my engine is far from stock, and i use 93 oct.  anyone else have an opinion or idea about making the timing advance further than stock?
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: February 03, 2009, 05:20:19 PM »
There's some thoughts by Hondaman in the FAQ section where he talks about modifying the 750's advancer.
mystic_1
- John Augustus Shedd
