Poll
How often do you lube your drive chain chain?
Every ride
100-500 miles
500-1000 miles
1000+ or when I change oil
2000+
When I replce the chain and fix hole in the case
Author Topic: How often do you lube your chain?  (Read 22632 times)
Hop on a Honda
Re: How often do you lube your chain?
« Reply #25 on: November 11, 2005, 12:54:32 AM »
Ugh  :o So, do you still like pie or does it bring back nightmares  ???
A/? >:(
 Pie never touch the stuff.
I have learn't that the unknown is still unknown! except for poor old mum's apple pie.
BUT still like Key Lime Pie in Key West washed down with some good Tequila and a good margarita is always welcome.
Dave
Offline dpen
« Reply #26 on: November 28, 2005, 03:17:27 AM »
Interesting point Ofreen.
I have an "X" ring chain on "the rat" & have used diesel fuel as a cleaner for years (many of) on all my bikes.
I've never used Wd40 because of the damage it did to the rubber boots on a mates car when we tried to fix the suspension squeaks about 30 years ago.
Could you check out the condition of your"O" rings & give me an update?
Online ofreen
« Reply #27 on: November 28, 2005, 04:35:09 AM »
The RK chain on the 750 has been on there for 14 months and almost 7000 miles.  The o-rings look fine and the chain hasn't needed any adjustment yet.  Another thing I've noticed is there isn't any rust on the outside of the sideplates like I was getting with chain wax.  The chain is staying cleaner, too.  I have a ways to go yet before I can decide if WD40 is adequate, but so far so good.
Greg
'75 CB750F
Greg
'75 CB750F
Offline dpen
« Reply #28 on: December 08, 2005, 01:53:54 AM »
Looks like I'll give the WD40 route a go.
I've had a great run from using diesel (great mileage, minimal adjustment needed etc) but hell, it's a dirty, messy way to do things.
« Reply #29 on: December 28, 2005, 04:25:40 PM »
I lube my Tsubaki Sigma O-ring chain every 500 or so miles with Chain Wax which stays in fairly well.A previous Tsubaki chain got 16,000 miles + out of it (on a 2 month trip trans-USA and around Mexico and back in ALL riding conditions possible  -Im sold on Tsubakis!).
Cheers
Andy in Boston
Gibson
« Reply #30 on: January 17, 2006, 06:59:58 PM »
I use Irving blue grease for tierod end's bushing'd ect some fling's off but if put on the inside of the chain it stay's pretty good no idea on chain mileage though and never though of ever cleaning a chain and i've had alot of bikes. sometimes i use real chain lube forget the name but the grease seem's to stick better.
Offline mrbreeze
  • Not your average
« Reply #31 on: January 17, 2006, 09:24:26 PM »
Gosh old man Dave!!(Thanks for translation Steve D!!!) Sorry to hear about results of chain lube pie but the big question is.... How did the chain work out? Actually,I just use the aerosol can chain wax and check adjustment every few hundred miles. Probably better for the chain to get dunked in liquid grease and done properly once a year but I am not going to go through all of that every 200 miles.
MEMBER # 257
Offline rpyles
  • My 1970 750 K0
    • Richard's Site
« Reply #32 on: January 18, 2006, 05:01:50 AM »
So now that we all have these clean, well lubricated chains, what about the automatic oiler on the bike? Is there a way to turn it off or disconnect it?  Or do you leave it on anyway?
Richard
Richard Pyles - 70 CB750 K0
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #33 on: January 18, 2006, 05:46:41 AM »
Yes, the auto chain oiler is adjustable between zero flow and "really mess-up my rear wheel." There is a slotted screw within the front sprocket mount. Turning it will either expand (slow flow) or contract (increase flow) sort of a rubber stopper-like part.
Offline dusterdude
« Reply #34 on: January 18, 2006, 10:13:26 AM »
bob,turning it which way will do what
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #35 on: January 18, 2006, 10:32:40 AM »
both ways... ;D
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #36 on: January 18, 2006, 10:50:28 AM »
Sorry, should have included that. Here's better detail.
Offline rpyles
  • My 1970 750 K0
    • Richard's Site
« Reply #37 on: January 18, 2006, 02:06:02 PM »
Thanks, Bob - a picture is worth a thousand words.  ;)
Richard
Offline dusterdude
« Reply #38 on: January 18, 2006, 05:06:46 PM »
thanks bob,you`re the greatest. ;)
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Egil
SV: How often do you lube your chain?
« Reply #39 on: January 21, 2006, 11:10:48 AM »
How shall l tell this .
In my(1977) Honda Original Service Manual CB750F2/K7   , this page is`t there  ???.
They ref. to O-ring chain  ;D!
« Last Edit: January 22, 2006, 12:07:40 AM by Egil »
73 de La2vpa.
Egil.
On The Edge.....That`s Where We Live Every Day.
My bike :
http://bike.no/member/photo.php?id=1605
cntrhub
« Reply #40 on: January 28, 2006, 10:28:15 PM »
So Dave... do you purge on your chain now? Must save on chain lube... and biodegradable too! I hope we can laugh at this now. I was wondering....who else got sick/died eating that pie? Were you the only lucky one?
I'm going to let you experiment with the WD-40. If I were to use a water displacer lube/penetrant, it would be GM Goodwrench Heat Valve Lubricant.
The chain sprays have to work fast before they tack up. You kind of wonder if the sealed o-ring chains can get 16K even if not lubed? The can sprays are hard to clean because of the tackiness. WD and Heat Valve would be a snap to clean, having the benefit of thin running lube. Whatever is peppered on the bike and clothes is much less than oil or spray I would assume.
Which brings us to oil. My gig is 90W rear end lube. I used to hand squirt (gun) each of the 4 sides of the chain. Now I'm thinking I can kill two birds using a stiff brush. Oil is a cleaning detergent, and brushing on 90W is going to be a mess, but I will do it after every ride. Clean gear oil brushed on will both run the grit off the chain, plus lube the chain at the same time.  Let it drip dry over night, and hand dry the links before a ride. Gear oil cleans easier than chain lube.
You have me thinking about the WD/Heat Valve Lube angle.
Offline Egil
« Reply #41 on: January 29, 2006, 10:59:51 AM »
You can clean the chain whit using  diesel fluid ;)  you do`t need a special chemical drougs
 ( diesel fluid same as farmersand  and Land-lord`s use on theirs Tractors)
Oh I forget that mostly all "big" trucks goes on petrol in the north American and a few different areas :o
73 de La2vpa.
Egil.
My bike :
Online ofreen
« Reply #42 on: March 12, 2006, 07:23:20 PM »
Here's an update to the WD-40 experiment.  After 8500 miles since new, I've adjusted the RK chain on the 750 for the first time since the adjustment I did at around 200 miles.  It didn't take much, just turned the adjuster bolts two flats.  The sprockets look good and chain still runs quietly.  The nice thing has been how clean everything is staying.  So far, so good, so the experiment continues.
Greg
'75 CB750F
amattel
« Reply #43 on: April 05, 2006, 09:36:43 AM »
Thanks for the update!  I am ready to drop the messy stuff and hop on the wd-40 train!
Adam
TARKUS512
« Reply #44 on: May 26, 2006, 07:56:53 AM »
Do you mean with my left hand or my right?
Offline Stormer
« Reply #45 on: June 11, 2006, 07:28:10 PM »
Motul chain lube at every 200 miles.
Sory the bad english.
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #46 on: July 15, 2006, 08:25:42 PM »
This will probably sound like yet another endorsement for Scottoilers....but anyway here goes.
My last bike was a '00 VFR800, bought new in '01. I fitted a Scottoiler at the time of purchase. When I sold the bike last year it had 89,000km on it and was still on the original chain/sprockets. I adjusted the chain maybe half a dozen times in the five seasons I rode the bike. It, and the sprockets, still looked like new.
I rode a KLR650 for part of a season (with a Scottoiler) and in 15,000km there was no appreciable sprocket wear visible.
I have just replaced the chain/sprockets on the CB650 and fitted a Scottoiler straight away. It will be interesting to see how they last......
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Zip
« Reply #47 on: July 30, 2006, 07:52:09 PM »
I lube my chain with motor oil applied with a 1" paint brush.  For me, this is the best of all worlds.  The brush and oil cleans the chain, the brush applies the oil exactly and sparingly, so there is little to no splatter, and motor oil is waaay cheaper than any of those spray on chain lubes, some of which ain't worth sh*t <cough;chainwax;cough>, imho.
My FJ has about 25k miles using this method, with many k to go, and the chain has only been adjusted 3 times.
Zip
Offline stresssolutions
  • 4 years on a motorcycle, Time Flies!
  • 03 RoadStar, I miss my Honda
    • bloggy thoughts
« Reply #48 on: November 18, 2007, 12:39:49 PM »
How about an update, year or so later??
Enjoying life, one day at a time.
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
« Reply #49 on: November 18, 2007, 01:22:02 PM »
I am really wonder if anyone out there ever ran a 0-ring chain on a bike without lube for any length of time.  I lube the chain and it collects dirt and the oil seems to just fly off.  I wonder if i am just jerking off.
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
