Author Topic: '78 CB750 exhaust pipes on a '75  (Read 625 times)
Offline katmol
« on: February 09, 2009, 04:32:52 PM »
Will a set of '78 exhaust pipes and mufflers fit on a '75? I know I'll need to make some brackets for the mufflers but will the '78 header pipes work with the '75 head and mounting hardware?
'74 CB750K Tracy Project
'76 "Modified" GL1000
'77 CB750A Blue
'77 CB750A Red
'79 CM400A Hondamatic
'81 CM400A Hondamatic
"Gone but not forgoten."
'76 CB750A Muscat Green
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
'78 750K Black Dresser
Offline GammaFlat
Re: '78 CB750 exhaust pipes on a '75
« Reply #1 on: February 09, 2009, 05:26:57 PM »
oh my!  I think you're making a big mistake.  You see, I need those pipes.  :)
If they're in good shape, 77/78 pipes are worth enough dough to get you a new 4-1 or possibly a cyclexchange.net 4-2-1.  Don't chop 'em up if they're good.
To answer your question, you can make them bolt up in the front but not in the back.  You'll need to put studs in your head on your '76 or older - which means you'll have to remove the "spigots".... two screws per spigot.  The backside probably won't mount up so nice.  If you want pics of how a '77/'78 looks with pipes on and what a K6 looks like "back there", I'll take some for you.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
