Author Topic: HM300 on a K4?  (Read 1135 times)
stretch
HM300 on a K4?
« on: February 12, 2009, 01:37:42 PM »
I've got a CB750K4 which currently has the original HM341 exhaust system, and the exhaust is due for replacement soon.  I had planned to save up and buy a new HM341 replacement system, but I'm wondering how practical it would be to instead put on a HM300.
Is this something that would just fit on without any modifications, and would it be worthwhile?  I'm assuming it would sound better, and maybe give a bit more performance.
(Post edited to reflect that I meant to say HM300, not HM340!)
« Last Edit: February 12, 2009, 03:25:44 PM by stretch »
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: HM340 on a K4?
« Reply #1 on: February 12, 2009, 02:07:54 PM »
If you are spending the money why not go for the HM300's? You can still get them when I checked last, they are expensive though  :o
I would like to when I hit the lotto  :D
I think they should fit fine, with no problems.
stretch
Re: HM340 on a K4?
« Reply #2 on: February 12, 2009, 03:25:00 PM »
D'oh!  That's what I meant, HM300.  I think I need more coffee!
Offline hoodellyhoo
  • CB350F
Re: HM300 on a K4?
« Reply #3 on: February 12, 2009, 05:44:00 PM »
I think a fellow named "Jonsey" did it on his later 750 just fine.
Offline dpender836
Re: HM300 on a K4?
« Reply #4 on: February 12, 2009, 06:01:03 PM »
I'm glad you asked this question, I was actually thinking of putting the HM300 pipes on a K2, We need all you CB750 experts to voice your opinion, is this politically incorrect or a big NO-NO or is it done all the time?  I also have been told they sound and perform better,is that true? looking forward to your answers. Thanks
Offline Johnie
Re: HM300 on a K4?
« Reply #5 on: February 12, 2009, 06:16:19 PM »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
stretch
Re: HM300 on a K4?
« Reply #6 on: February 12, 2009, 07:16:23 PM »
Check this out...
http://forums.sohc4.net/index.php?topic=45301.msg473654#msg473654
Good info for you..
Thanks for that.  Sounds like it was a straightforward swapover on his K3, so I assume it'd be the same for my K4.
I'm trying to keep my K4 nice and original, so putting HM300's on it would be a bit of a departure from that theme.  But the idea of a throatier exhaust has an irresistable appeal.  If I ever won the lottery I'd buy both sets NOS and change between them as the mood takes me :)
Offline Jonesy
  • Shop Rat
Re: HM300 on a K4?
« Reply #7 on: February 12, 2009, 07:23:00 PM »
Why, yes.. I did!  ;D
The only mod is you'll have to re-jet. My K3 with the stock 341's was running the specified 105 mains. Now with the 300's I had to install 115 mains. I left the jet needle in the 3rd position and the bike runs great. The sparkplugs (NipponDenso X24ES-U) have a nice tan color to them.
The 300's flow better (the small glass-pack baffle is the only thing in the way of it being an open megaphone) and have a throatier tone. Still civilized at idle and cruising speeds, but make a pleasant growl when the throttle is opened!
As for worthwhile, I would say so. Granted, my bike also has a 17-tooth front sprocket, baffles removed from the airbox, etc. so the setup is more like an earlier CB750. But, they sure sound nice!
stretch
Re: HM300 on a K4?
« Reply #8 on: February 12, 2009, 08:16:39 PM »
Thanks for that Jonesy, that's excellent info.
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: HM300 on a K4?
« Reply #9 on: February 13, 2009, 06:19:52 AM »
If you're going to spring for new pipes, buy the HM300's. The sound makes 'em worth every penny. They sound awesome on my K3.
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
