Author Topic: '77 cb550 carb issues  (Read 9990 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« on: October 09, 2005, 12:48:59 PM »
this sounds like such a typical beginning to a thread, but here goes...
i've rebuilt the carbs on my '77 cb550, and it won't run without the choke all the way closed. ok, before you just tell me my carbs aren't cleaned properly, consider the following:
all passageways through the primary and main circuits are clean and clear. i'm running uni pods and a 4 into 1 header, with no exhaust at the moment. this being the case, i jumped up from a 90 main to a 110 as a starting point. the bike fires right up with the choke on, and at full throttle will run fine with the choke off, but won't run at all at idle at all like this. i pulled the carbs twice and blew air through the idle circuit, just to triple check. clean.
the '77 and '78 carbs are different than the preceding version, with screw in mains, enabling easy rejetting. however, none of the aftermarket manuals list info for these two years, and i'm wondering if the floats are just set too low and fuel can't reach the primary jets. i can't find a listing of a different height than the 22mm height of the earlier carbs.
anyone familiar with this situation or these specific carbs? sound like a reasonable explanation?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
servopc
Re: '77 cb550 carb issues
« Reply #1 on: October 09, 2005, 05:23:28 PM »
I read somewhere online that 16 mm was the correct height. The author actually mentioned the 22mm callout being incorrect. I'll try and track down the site with the article. I just picked up a CB550K, '78 . I suspect we have the same carbs, screw in mains and pressed in idle jet. Even the factory manual I picked up has different carbs pictured. I'm trying to track down some documentation for this thing. If I find the correct specs and/or the article I'll post them.
Offline paulages
  • 1976 cb735
« Reply #2 on: October 09, 2005, 06:09:16 PM »
i know that having a muffler will help, but ii plan to run a yoshi copy which is quite free flowing, and should perform similar to an open header.
i found this on another thread:
"Here's the specs from the Honda manual addendum for 1977:Main jet#90; air jet#130; slow jet#38; slow air jet#150; jet needle setting 3rd groove E2349F-3; float height 14.4mm (0.57in.)"
the incorrect float height could very well be my problem (i was going off the 22mm height of the '71-'76 models).
does anyone kow how to deal with rejetting the pilot jets to accompany larger mains? i'm told the "detuning" of the '77-'78 models (using 90 mains) was a response to EPA regulations on fuel usage. all the earlier models had 100's, which is why i jumped all the way to a 110 with pods and a 4-into-1 header. i assume the pilot jets have to be drilled out larger, because they're pressed in, but i don't want to just start drilling without knowing where to begin.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Dennis
« Reply #3 on: October 09, 2005, 08:09:04 PM »
i've rebuilt the carbs on my '77 cb550, and it won't run without the choke all the way closed.  ..... the bike fires right up with the choke on, and at full throttle will run fine with the choke off, but won't run at all at idle at all like this. ..... and i'm wondering if the floats are just set too low
...... i can't find a listing of a different height than the 22mm height of the earlier carbs.
Did you reset the floats to 22mm?
Did that not seem like a rather ectreme adjustment to you? Or perhaps the floats are installed upside down?
I'm not familiar with the later '77-'78 carbs, but I know that it is not unheard of for floats to be installed reversed on some models, not sure which.
Anyway, you have to figure that if the carbs are only suffering from varnish, gum and fuel tank sediment, and if they appeared to be relatively unmolested, that perhaps the bike was running when parked.
I prefer to start adjusting from some known point. When preparing an unknown set of carbs I will clean and check every passage to be sure it is clear. Examine all parts for wear. I will check and record every adjustment and jet size that I can locate. I will reassemble with all adjuxtments unchanged. I will then start the engine and then determine if adjustments really need to be made.
Offline paulages
  • 1976 cb735
« Reply #4 on: October 09, 2005, 09:22:00 PM »
i follow very much the same regimen...however, i got the bike from someone else who had already torn into it. when i bought it, it ran under the exact same conditions. i figured he had simply not cleaned them well enough, so i bought a gasket kit and recleaned them. they looked spotless when i opened them up, but i blew compressed air through every circuit and reinstalled. i checked the floats, and when they were exactly 22mm, as the clymer's specifies for the other years, i just left them alone. my guess is that he did the radical adjustment during the first "rebuild."
i put them back in, and having the same condition, pulled them AGAIN. double checked everything and began to suspect the float level, and here i am. i'll repost after i get a chance to reset them and test.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Dennis
« Reply #5 on: October 09, 2005, 09:30:40 PM »
i follow very much the same regimen...however, i got the bike from someone else who had already torn into it. ..... my guess is that he did the radical adjustment during the first "rebuild."
Sorry, but I obviously confused you with one of our beginners.   :D
Sounds like you're on the right track,
I'll be looking for your next post!  ;D
« Reply #6 on: October 09, 2005, 10:56:21 PM »
The slow jets are fed from the bowl at a higher point than the mains.  The floats are supposed to be set at 14.5mm for the 77 CB550K.  And, setting them at 22mm may well make the fuel level so low as to starve the slow jets altogether.
After you fix that, it should have improved idle.  But, there may not be enough adjustment range in the Idle mixture screws to compensate for the pod filters.  These usually have far less restriction than the stock airbox and paper element filter which acts similarly to partitial choke.  This increases the vacuum in the carb throat, causing all the jets to flow at an increased rate due to the pressure differential across the jet orifices. The pod filters reduce this effect and the Idle Mixture Screws have a very limited range of compensation.
Don't be too surprised if you eventually have to increase the slow jet size to get the idle mixture rich enough for smooth pickup at low speed with the twist grip.
Also be aware that the main jet size has the most effect on mixture with the throttle at 3/4 to full open. The main jet feeds the needle jet.  And the needles attached to the slide further reduces the fuel flow and mixture between 1/8-3/4 throttle dependent on the taper profile and needle depth relative to the slide opening.
I like to think of these carbs as having three distinct fuel metering devices that are each active relative the slide position or throttle setting; the slow circuit, needles, and mains.
Lastly, the book values for carb settings are really only correct for the bike in stock configuration.  They are a good baseline to start off with these settings.  But, changes to intake and exhaust have a dramatic effect on jetting and adjustment, particularly with the 77-78 CB550 carbs.
Offline paulages
  • 1976 cb735
« Reply #7 on: October 10, 2005, 01:12:03 AM »
i reset the floats to 14mm, put a bit of carb cleaner in the end of the idle circuit, covered up the air screw hole, and blew air through it, just to make sure they were clear. each produced a nice spray from it's corresponding slow jet...
but the tip of one of the idle srews broke off in the throttle body when i was resetting them. now i'm stuck either finding a replacement idle adjustment screw (hard for these years) or buying a rebuild kit for a '76 set of carbs i have, and changing the intake manifold out to match them. dammit!!! anyway, that other set should be easier to rejet, as the slow jet is removable and therefore replaceable.
thanks for the advice, two tired. i have a pretty decent grasp on the workings of a carberator, but have had little experience with the slide carbs in the sohc 4's. (i'm more familiar with the CV carbs on a lot of the twins) rejetting is another story.
another question, however...
do i have to separate the carbs to pull the slides out and change the notch setting on the needles? the '77 carbs look like it may be possible without doing so, whereas the '76 set looks like a doozy to deal with. even with rejetting, i'll likely have to raise the needle up a bit.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #8 on: October 10, 2005, 02:35:01 AM »
also, two tired,
i read a previous post, where you discussed the engineering of honda vs. hacks trying to improve something that was pretty damn good to begin with. i agree with you, really, but from what i understand, essentially the same carbs were "detuned" through the years to satisfy emissions standards. for example, the '77-'78 carbs using a 90 main instead of a 100. you seem to know a lot about these carbs, so i suppose i'm telling you something you know very well. in this day and age, i don't really want to decrease my MPG, but i wouldn't mind a slight power increase. either way, i'm breathing life into a really trashed bike, by doing a complete tear-down and rebuild from a freshly powder coated frame up.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #9 on: October 10, 2005, 03:54:18 AM »
Whilst you got air out of the slow jets there are several ceoss drillings in them you cant see that get blocked and no amount of carb cleaner or air pressure works. You can get the jets out by gripping gently with vice grips and pulling/twisting at the same time, clean out thouroughly and re-seat with a light tap from a soft faced )Nylon or copper NOT fibre) hammer
osnomad
« Reply #10 on: October 10, 2005, 06:34:20 AM »
I had this exact same problem on my 77 cb550 when i first bought it. TwoTired is correct in that the float height is starving the slow jets (His knowledge was of immeasurable help to me, thanks TT!). I also agree 100% with bryanj in that the slow jets are IMPOSSIBLE to clean fully without removing them. I swore up and down and left and right that those slow jets were clean when I was having problems. I was reluctant to pull them out for fear of ruining them so I sprayed a full can of carb cleaner thru the idle circuit from both directions and was sure that had to have done the trick... It didn't. I finally gave in and pulled them out carefully to find that all the cross-drilled passages were still completely clogged, even after all the cleanings I did and all the soaking and everything else. I also found that to really get it to stop running lean with my stock jets I HAD to put the airbox on with an air filter installed. I was doing all my testing with the box disconnected. It wasn't till I put the airbox back on that I really had it running correctly.
« Reply #11 on: October 10, 2005, 10:42:34 AM »
There are at least 4 holes from the atmosphere into the slow circuits in the bare body of these carbs; Air jet, slow jet, carb bore exit, and when the idle mixture screw is removed, the screw hole, too.  When you pressurize that passageway, each one of these exits should be verified flowing.
The slow jet has a small tube as part of it inside the carb body with rather small cross drilled holes.  This forms a small emulsion tube where the fuel is premixed with air from the air jet.  Between, the pilot jet and the carb bore exit is the I.M.S. (Idle Mixture Screw) which meters the fuel emulsion from the slow jet.
These small emusion tube holes are very difficult to clear effectively without removing the slow jets from the carb bodies.  They are pressed in, but can be removed (yank them straight out), cleaned, and tapped back into place.  If you are considering abandoning these carbs in favor of others, what have you got to lose by yanking the jets?
A broken IMS is indeed bad news.  I fear the valve seat was also damaged when these were way over-tightened.  Distorted seats make equal settings across the carb bank difficult to achieve.  If you think the seats are salvageable, I can send you a used IMS from my junker set.
This is why I alerted you to the throttle position aspect wrt jetting.
No, I think it is unwise to separate the carbs from the bank.  But, you will likely have to remove the set from the bike. The needles exit the carbs with the slides through the top of the carbs.  Remove two screws from the carb tops.  Loosen the screw on the arm at the actuating bar.  Then a No. 1 phillips to remove the screws deep in the slides (slides lowered).  The actuating arm then will swing up out of the way to gain access to the slides and needles.  You will have to synchronize the carbs after putting it back together.
also, two tired,
Actually, I think the 77-78 carbs were highly tuned for the bike in the configuration as sold to the public.  The polution control laws for motorcycles lagged behind those for the auto industry.  They weren't really on the books yet in 77-78.  However, the lean burn carbs WERE common in the auto industry.  Honda began creeping up on what was to become polution laws applied to motorcycles by "evolving" the slide carbs.  This was abandoned in favor of the CV carbs by the time polution laws actually took effect for motorcycles.  In parrallel with the anti air polution frenzy was also the anti noise polution effort, though to a lesser extent.  The stock exhaust for 77-78 CB550 was quieter than previous models. And, a bit more restrictive, for a bit less power at the top end.
I believe the 90 main was selected for these carbs to:
Lean up the high RPM range over previous years.
To match up the reduced main air jet size from #150 to #130.
To compensate the emulsion tube hole size and placement over that of previous years.
And, the restrictive exhuast made a bit less power at the high RPM where the main jet is dominant in the fuel equation.
The earlier carbs were actually sloppy in tuning by comparision.  Which makes them easier for the home mechanic to deal with when other bits of bike are modified.  However, both models had 22mm throat bores. And, with proper adjustments can be made to run equally well, regardless of what's been done to exhaust and intake changes.  I've no doubt the newer carbs can be made just as sloppy and over rich as the older ones, though, just by tweaking the right (wrong?) bits internally.
This link and the attatched chart may help you tweak the appropriate bits in the carbs to achieve your goals. (However, the pics don't work for me anymore. I have old computer equipment/software.)
http://www.motorcyclecarbs.com/jetting_1_your_keihin_W46.cfm
Offline paulages
  • 1976 cb735
« Reply #12 on: October 10, 2005, 11:45:20 AM »
thanks again, two tired,
i don't know how i overtightened that screw. for some reason the "light seating" just never came, and then it obviously must've gone too far. i don't know if i can get that tip out. i have a little jet drill set, and if i can find the right size i might be able to gently drill it out. this is very discouraging, since i already spent $60 on the gasket kit which would be useless for the older carbs, and have played with the damn things so much already. if i can get that seat cleared up, i would certainly take you up on that mixture screw,but i don't know whether to trust the seat anymore.
i have that set off of a '76, and a complete'74 parts bike coming in a couple of days. which do you think is a better set of carbs, earlier or later? other people have told me that the '77-'78 carbs were better, with the screw in mains, but they are also obviously harder to finagle with. i don't really have much of a desire to fight honda engineering, but circumstances have left me with the pod/ 4 in 1 header setup.
i will pull that pilot jet out, if only for #$%*s and giggles at this point. i could only find three atmospheric openings in the idle circuit though. the hole for the mixture screw, the carb bore exit, and the pilot jet itself. i know from rebuilding other carbs how clogged those pilot jets can be. i guess i was just feeling good about the fact that it seemed to be vaporizing carb cleaner when i blew compressed air through backwards.
i have cleaned and sync'ed the older type before, so at least they would not be such foreign territory.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #13 on: October 10, 2005, 12:50:12 PM »
You are best able to assess your situation and prowess. But, I don't think drilling is is the right answer.  Can you drill a tappered hole? The tip of the screw is right at the carb bore exit.  I think I would try and find or make a tool to push out the broken tip from the throat side of the carb.  It's tappered, so once it moves a little, it should fall out.
[quote author=paulages link=topic=4663.msg36247#msg36247 date=112896992
The earlier CB500/550 carb came with three setups from the factory (That I know of, anyway.)  Each carb body has the set up stamped on each carb body mount flange, top right.
Cb500 -  627B
CB550K- 022A
Cb550F- 069A
The setups were different to match the displacement, and exhaust type.  (They all had the same airbox/filter arrangement.
The only way to predict which would be best for your current set up would be to know how different the flow characteristics of your current mods are to the stock flow restrictions. ???
But, if I had to prognosticate, here's my thinking.  Were it not for the pod filters, I'd say to opt for the 069A carbs since they were set up for a 4 into1 by the factory.  But, the pods are likely to allow the carb throats to be closer to atmospheric pressure than the stock air filter, thus drawing less fuel from various jets.  So, at least, some of the fuel metering will need to be opened up to compensate and allow the mixture to richen up a bit.   Given the 627B carbs were for a lower displacement engine that had less suction on the carb throats (comparatively), these carbs would run richest overall in a CB550 application.  If too rich, then carbon fouled plugs result.  If all you have is 022A, well..., try it.  There's an old drag race saying, "run what ya brung".  (May have been a hill billy, given the pronunciation.) :)
It is certainly possible to modify any of the carb's setups to meets your current mods.  But, unless you are lucky or un-naturally gifted, brace yourself for a few hours of adjust and try.
Offline paulages
  • 1976 cb735
« Reply #14 on: October 10, 2005, 01:03:31 PM »
069A is what i've got, and i had originally considered them for that reason---they came off of a supersport with a 4 in 1 header. as a matter of fact, that's what my header is---a stock '76 supersport header. i'm not deadset on pods---one of my cb550s is a complete rebuild (cafe) and the other is just a ratter that i'm trying to get ridable and look good at the same time. the cafe would be nice with pods, and i plan to move the battery box and hide the electrical console under the seat. the reason i'm trying this with pods right now, is that i have been treating the ratter as my test bike...get it dailed in perfectly, and then apply that to the other one when it's ready.
given this, how does a 38 pilot, 110main, and one clip up on the needle sound as a starting point (with the pods and the 4 into 1)? i have no problem spending hours playing with this thing to get it right--this stuff is my relaxation therapy.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #15 on: October 10, 2005, 01:46:57 PM »
Are you using the stock 4 into 1 muffler, too?
With the 38 slow, you should be able to close down the idle screw where you can get the slow speed rich enough.  This needs to be over rich or your throttle pickup from low RPM will be wheezy.
Since the stock set up for these carbs was 98 main, my gut says that 110 will be too big.  But, again that's dominant when the throttle is at the 3/4 to WOT position.  If I were to go larger than stock (depends on muffler), I'd try 100's first.
The stock needle position is 2nd groove from the top (opposite pointy end).  If your plug's center electrode insulator deposits are white or nearly so while operating at 1/4-3/4 throttle, then yes, raise the needles a clip position.
I guess you already know that if you change one part of the metering system, you may have to go back and change other parts, too.  As none of them shut down completely when not dominating the fuel equation.  In these carbs, anyway, leakage happens.
Offline paulages
  • 1976 cb735
« Reply #16 on: October 10, 2005, 05:14:54 PM »
i may take you pu on those mixture screws at some point, but for now, i'm gonna order rebuild kits for the '76 set. i believe the mains in that set were 100's, not 98s but i'll have to double check. i went up so dramatically because of the intake actually. i figure one size is probably about right for a 4 in 1, maybe another if it's open. however, with those pods, it's surely gonna be sucking in a ton more air--maybe not with the increased velocity of the stock intake boots, but it is certainly less restrictive.
neither bike came with a muffler (one with no header either). the longer project will most likely get a yoshi copy a guy named carpy in L.A. sells. i was planning on running the other open, until the noise gets to me (and my neighbors) too much.
i've read so many people's different combinations off suggestions for calculating main jet sizes---add one for an earthquake in pakistan, another for a butterfly flapping it's wings in hawaii...anyway, i'll take these all with a grain of salt and experiment. hopefull i'll find something good!
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #17 on: October 10, 2005, 05:36:19 PM »
Ha, ha, good one, I like that.  ;D
« Reply #18 on: October 10, 2005, 07:14:18 PM »
Some of the rebuild kit suppliers don't differentiate between the various carb set ups.  If they supply 100 mains than for sure they don't care about how the carbs were originally set up or they assume its a 627B or an 022A.
The 069As are supposed to have 98 mains.  The needle taper profiles are different for each carb set up.  Also note whether the main emulsion tubes for the carbs are supplied in the kit.  These have different hole sizes that mix different amounts of air for the corresponding needle and profile.
Since you have 069A carbs, you may actually want rebuild kits for a different model, as it will give you more variations to try and match what your engine now requires with the pods and whatever restriction you finally have with the muffler or no.
Well, I disagree.  The engine has the same cam duration and lift, valve size, port diameter and cylinder displacement.  It's volumetric efficiency is about the same as a stock one.  The lack of restriction in the exhaust will help the flow a bit on the top end near WOT.  The lack of restriction from the filter will largely effect the barro pressure in the carb throat. It's the difference in pressure between the throat and the external atmosphere that determines how much fuel traverses a given jet orifice size. Jetting changes here are not so much the result of more suck from the engine, but the lack of partial choke offered by a restrictive air filter.
That's my theory anyway.  What do I know?  I don't want to kill your optomism.
The muffler restriction, or lack thereof, will have an effect on jetting for sure. Less restriction gives more scavenge effect from the four into one that become more dramatic as RPM increases.  It can be modal, too, and exhaust runner length, port timing, and RPM is interactive with the scavenge effect.  Are you planning on reving past the current red line?
Also the lack of back pressure can effect idle mixtures as it retains less of the burnt mixture from the previous fire cycle.
Yes, I find those rules of thumb are most useful for tuning thumbs. :-\
Offline paulages
  • 1976 cb735
« Reply #19 on: October 15, 2005, 01:19:23 AM »
okay, so i got some keyster kits, and some 105 mains to try instead of the mains supplied in the kit. given that my starting point is all a gamble anyway, should i stick with my original clip position on the needle, or should i assume that i'll also need more fuel in this range as well, and drop a notch? at this point, the header and carbs are from '76 F, going onto a '77 K engine, so the main differences from the stock setup are the open exhaust and pods.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #20 on: October 15, 2005, 10:20:38 AM »
What components were included in the Keyster kit and what model did it specify for it's application?
Are you using these internal bits instead of the stock ones?
Did it include the main emulsion tubes?  Did you change them?
The 069A emulsion tubes have bigger holes for air than the 022A.  And the needle profiles are different.
The earlier carbs ran pretty rich at idle.  It's what gave good throttle response from down low.
I know you'd like to hit the home run on the first installation.  But, the possible combination list you have now is pretty large.  How good are you at playing craps?  I don't know how to advise you given all the unknowns of the set up.  Were it me, I'd start with all the stock settings and parts.  Run it, read the plugs and then make adjustments applicable to throttle position and needs.
I had a 75 CB550K.  Came with stock 022A carbs, uni pods, and a mac exhaust, very open and loud.
It used 38 slows, 100 mains, stock needles (can't remember the clip position).  The engine ran well and the plugs were consitently light to mid tan.
cheers,
Offline paulages
  • 1976 cb735
« Reply #21 on: October 15, 2005, 11:10:28 AM »
the kit cam with 38 primaries, 100 mains, needle (i'll have to compare the profiles--if it's very different, i'll probably not use it...however, am i right that a longer taper=richer profile?), needle valve, idle screw and spring, and no emulsion tube. i pulled the emulsion tubes last night though (actually, i shot them out with compressed air), and all holes are very clean. maybe i'll start with the 100 mains in the keyster, as that is already 1 size up from stock. oh, and i am pretty good at craps actually...but maybe not roulette.
another question...there is a tube connecting each sets of carbs-- 1-2, 3-4---is this just the fuel line between the one that gets fuel directly and its neighbor? the brass tube connecting them had rubber feul hose around it.. one of the hoses is cracked, and i'm trying to figure out how neccesary it is, because i really don't want to separate them to put a fresh one on. i assume this is just to protect against fuel leaks of the brass line isn't pressed in well.
also, in between #2 and #3, there is a nipple. is this an atmospheric intake for the air jet maybe? air blows through it freely. it's amazing how different these carbs are from the '77-'78 ones. i rebuilt a set before, but i just cleaned it, replaced everything as per stock, and synced it. these, i want to understand the anatomy of as well as possible if i'm going to be tinkering with them.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #22 on: October 15, 2005, 02:23:46 PM »
The narrower the needle, the more fuel flows past it.  Of course, the clip position in the slide is interactive with taper profile.
The 069A idle screws are soild with 18 degree taper.  The other models have a hollow tip and cross drilled with 12 degree taper.  I never checked to see if the seat taper is machined to match the screw tip.
another question...there is a tube connecting each sets of carbs-- 1-2, 3-4---is this just the fuel line between the one that gets fuel directly and its neighbor? the brass tube connecting them had rubber feul hose around it.. one of the hoses is cracked, and i'm trying to figure out how neccesary it is, because i really don't want to separate them to put a fresh one on. i assume this is just to protect against fuel leaks of the brass line isn't pressed in well.  also, in between #2 and #3, there is a nipple. is this an atmospheric intake for the air jet maybe?
Between 1-2, and 3-4 are two interlinking tubes.  The smaller 5mm ones are bowl vents to atmosphere. On two and three carbs two hoses fit on them and route up and then down between engine case and swing arm.  These are the bowl vent "supply" lines and ensure that atmospheric pressure is present on the fuel surface in the carb bowl. This is the pressure that pushes fuel through the various jets.  The larger 1-2,3-4 interlinking tubes (11mm?) are where the fuel supply Tees fit.  The air jets (feeds for both slow and main emulsion tubes) are located at the carb main bore entrance.
Anything, I missed?
Offline paulages
  • 1976 cb735
« Reply #23 on: October 15, 2005, 06:42:54 PM »
Anything, I missed?
yeah, should i worry about the cracking hose covering the interlinking tubes? also, are the tubes attached to the 5mm vent nipples neccesary?
the mixture screws that came with the keysters are the cross drilled versions. i guess i'll be using the old ones...no big deal, as they look fine.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #24 on: October 15, 2005, 07:24:23 PM »
Well, Honda though they were important enough to include during manufacture.  They didn't put many parts on the bike that weren't necessary.
It will run without the tube or a crack in it.  But, the areodynamics of the bike will put high and low air pressures among different parts of the machine from turbulence.  Imagine if one carb had a high pressure pocket on one vent and another had a low pressure pocket.  This would effect how much fuel would flow through a jet on a particular carb.
These vents as well as the carb overflow stand pipes all had tubes connected and were fed from an air pressure source just ahead of the rear wheel.  I don't know for sure.  But, maybe honda found this point to be a place where aroedynamic forces were neutral.  Maybe not.  But, for sure this made all the carb see the same pressure to exert on the feed side of the jets for all four of the carbs.
I have installed that short connecting vent tube without separating the carbs.  I used brand new, as-supple-as-you-can-get, new tubing and silicone spray. (and a bit of struggle with forcepts)  The carbs were still on the bike, too.  I don't recall it as fun, though.  And, my vocabulary was limited to four letter words for the duration of the experience.
Do you feel challenged?
Offline paulages
  • 1976 cb735
« Reply #25 on: October 15, 2005, 07:51:04 PM »
challenged?  i never turn down a challenge!  (unless it involves alcohol, firearms, and blindfolds)
through the cracking, i thought the rubber hose was actually covering a solid brass tube. now that seems like a stupid question. of course it needs replacing. i'll install the vent tubes as you advised, i was just curious what you thought the difference would be, and as always you provided an interesting answer.
hopefully i'll be able to go to my shop and put the carbs back together tonight, though i won't be able to do any road testing until i put the brakes back together---front and rear.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #26 on: October 16, 2005, 01:05:39 AM »
okay, replacing the hoses was no big deal. decided to keep the original needles, as they are in good condition, and the new ones seem to have the same profile, but are fatter.
however, i have encountered an entirely new problem. first of all, the idle jets seem to not really thread very tightly, and even worse, the float bowls won't go back on! i thought i pulled the float bowls myself, but come to think of it, they may have been just been loosely threaded (much of this bike came in a box), and not on tightly. it actually looks like the float bowls are from a different carb set or something.
am i crazy? the idle jets are exactly the same as the old ones. i know that the spring that sits on top of the main jet puts pressure on the float bowl, holding the jet in place and putting pressure on the float bowl,  but this is entirely different. i used a micrometer to measure the height of the idle jet, and the depth of the space in the float bowl where it bottoms out, and it just won't fit.
before i frantically seek out ANOTHER set of donor carbs, can anyone think of something really stupid i might be doing?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #27 on: October 16, 2005, 11:10:34 AM »
okay, i think i am crazy...i woke up this morning thinking about those damn carbs. it was really late last night when i was reassembling them, and i'm thinking i was just trying to put the idle jets where the screw that holds the needle valve clip goes. if so, then yes, i was being really stupid, or rather i was really tired and had had a few beers, and wasn't using my noggin. anyway, later, i'll go and figure out if i can put the jets in the right place, or if that indeed was my problem.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #28 on: October 16, 2005, 11:23:32 AM »
There are pretty good pics of carb internals in the Honda Shop manual.
It's available on this web site somewhere.
If that doesn't help, I can take some pics and post them if you need further parts orientation.
But, at this point, I don't really know how else to help.
Offline paulages
  • 1976 cb735
« Reply #29 on: October 16, 2005, 11:50:04 AM »
like i said, i believe it was just pure sleepy foolishness. i've rebuilt 069A carbs before...don't know what's wrong with me. if my early morning hunch was correct, i'll be fine.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Raceshooter
« Reply #30 on: March 07, 2009, 06:33:05 PM »
Sorry I'm so late on this post. But, I'm in the middle of "this problem" and have had the carbs off twice now, and can idle the bike with the choke pulled. I was able to fish 28 gauge wire through the slow jets on my '77 carbs. I don't know that they are 'clean' yet. Does anyone know what size (either inches or mm)wire or drill that a clean jet should be able to pass? In other words, I don't know what's clean. Does the 38 on the '77 carb slow jet mean .38 mm?
Thanks - Jim
Raceshooter
« Reply #31 on: March 07, 2009, 07:01:03 PM »
Looks like I answered my own question. Apparently #27 gauge wire or a #79 drill, will get very close to .38mm or .014972 inches.
-Jim
GOSH
Re: '75 cb550K1 carb BALANCING AND ADJUSTMENT
« Reply #32 on: March 13, 2009, 07:08:30 AM »
Guys
I have a 1975 CB550K1 which I had parked up for 12 weeks...wonderful Irish weather. It was running fine previous to this though I do only have it for a year or so. When I took it out it ran like a wounded dog with no power so I went about removing cleaning tank. Removing carbs taking head and bowl off and removing all bits inside -cleaning everything thoroughly and re-installing with new seals and I am ready to put back in.
How I wnat to do a carb balance (and I have a carbtune meter for this) and also adjust idle etc but the manual I have for the bike does not give great detail.
Can anyone help with a minuture blow by blow of what to do from experience to get bast results. Effectively as I can see Carb is in good condition.
Any help would be great.
Thanks
Offline dragon79
« Reply #33 on: March 13, 2009, 12:32:38 PM »
i also have 77 550k and have carbs off. my carbs have 42 pilots not 38? 92 mains.
« Reply #34 on: March 13, 2009, 02:25:15 PM »
Carb models and internal parts changed in accordance with both the model year and the model type (F/K)
There is a chart in the FAQ pointing out some of these differences.
simcha
« Reply #35 on: April 11, 2009, 07:13:51 PM »
I know this discussion about carbs is old but I found out something relevant. I was trying to clean the slow carb by removing the pilot screw and putting a small wire thru the slow jet and so forth and I thought it was clean.  I then pushed a 1 foot  piece of vinyl tubing on the jet and filled it up  about half way . To my surprise there was no flow of carb cleaner in the jet it just stayed in the tube. I tilted the carb back and forth and the carb cleaner in the tube started turning colors and so I knew it was washing crud out. I emptied the initial crud out and filled the tube half way again and after letting it sit for a half an hour, finally it broke thru and washed it out and the carb cleaner was clearly running thru the jet. Then I was able to run carb cleaner thru from every direction. The lesson is, don't assume that just because you spray cleaner and compressed air in it that the slow jet is clear.
