Author Topic: changing the rake  (Read 800 times)
Offline pinnacle
changing the rake
« on: February 16, 2009, 02:35:47 PM »
how difficult do you guys think it would be to increase the rake on a cb550 and where could i take it to get done?
1974 cb550, 1978 cb550, 1984 honda shadow vt750
Offline Alan F.
Re: changing the rake
« Reply #1 on: February 16, 2009, 03:09:26 PM »
To increase the rake, you have options.  You could hack the neck off and weld it back on at a different angle, hopefully the shop you pick does a good job as there are safety concerns there if the do a poor job...  Or you could find a set of raked triple trees.  I'm not personally in favor of either method for my current bike, but some other project someday probably will go with option #1.
How difficult?  Can you use a grinder, measure acurately and weld?   I'd suggest making up some sort of a frame jig so that you could keep the neck square in relation to the rest of the frame.
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: February 16, 2009, 04:27:10 PM »
The real question should be, why are you changing the rake?  What trail figure are you aiming for?  The wrong answer here could kill you.
mystic_1
- John Augustus Shedd
