Author Topic: painting carbs, what paint to use? gas safe  (Read 15740 times)
Offline jason teamshralp
« on: February 17, 2009, 12:07:06 AM »
I want to paint my carb bodies black to match the motor when I reassemble my 350 motor. I read from a google search of "painting carbs" that some people have used brake caliper paint with success. I was wondering if there are any other ideas. Would the high temp paint for the engine suffice? or is there another option?
Krixxer
Re: painting carbs, what paint to use? gas safe
« Reply #1 on: February 17, 2009, 04:30:04 AM »
I use polyurethane paint extensively at the shop. It has tremendous chemical resistance and should not have any problems with it @ 250F.
« Reply #2 on: February 17, 2009, 01:51:10 PM »
is that a paint i can put on at home? do i need a spray gun or does it come in a can?
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« Reply #3 on: February 17, 2009, 03:01:32 PM »
interested in this as well..... i would think that the hightemp motor paint would suffice.
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
« Reply #4 on: February 17, 2009, 04:08:39 PM »
Just me -  but I think I would keep the paint off the carbs. If you ever wanted to do an aggressive dip cleaning,not that any old Honda has ever needed it  :D it will probably strip paint and make quite a mess.Polished metal,and carbs can get quite bright make a nice statement and would be easier to maintain.
Krixxer
« Reply #5 on: February 17, 2009, 04:45:33 PM »
not sure how chemical resistant hight temp paint may be but if you have some handy just try to wash it off with some gas.
The reason why i mentioned poly paints is because in most cases they are rated not to fail the MEK (methyl ethyl ketone) test; Apply MEK to a rag and wipe 100 times over the painted surface. Should have no loss of gloss or color. It the paint can take MEK gasoline won't stand a chance.
Unfortunately you really need some equipment to be able to use this stuff so you may be somewhat limited in you selection of material.
I'd love to help but somehow I doubt we are anywhere close to each other.
« Last Edit: February 17, 2009, 04:48:40 PM by Krixxer »
« Reply #6 on: February 17, 2009, 04:50:33 PM »
it think im just gonna go with the hightemp engine paint after the proper cleaning is done. I dont mind dealing with the paint if ever i need to dip it again. I just dont see me needing to dip it for a while as it will be ridden everyday and rarely have a chance for the carbs to build up crap. and when they do ill just deal with the paint coming off.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Krixxer
« Reply #7 on: February 17, 2009, 05:00:02 PM »
There is no reason why your stuff shouldn't last just as long or look as good after all it's mostly prep and patience and they have never been able to package either in a can!
« Reply #8 on: February 17, 2009, 05:17:11 PM »
MIDNIGHT- Jealous -  wish I could get your ride time down in FL.Up here we have WAY to much down time, Got my shovel ready for the next snow,and it hard on the bikes,Warm and Cold makes moisture,condenses on metal,Spring is hard on on a Honda up here.
Offline Steve F
« Reply #9 on: February 17, 2009, 06:34:19 PM »
I wouldn't think that paint on carbs would be someting I would like in the long run.  If they start to look crappy after a few months, you have to strip and re-do everything.  I just polish up the outside carbs that are visible (#1 and #4).  When they start to look a little drab, I just spray 'em down with the Valvoline carb cleaner, get out the metal polish and the Dremel with the felt tips for the tight areas.  Nice and shiney again.  ;D
« Reply #10 on: February 17, 2009, 06:45:54 PM »
ekpent... the bike will hopefully be done sometime end of this month beginning of the next and it will be ridden just about every day of the year. may sit a day here or a day there. but its year round riding down here. It gets cold to make a ride miserable but if you wear the right things its livable.
steve, I get what your saying. I would probably polish them but im down here for school and without my bench buffer. so painting it will be.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Steve F
« Reply #11 on: February 17, 2009, 06:51:02 PM »
I don't use a bench buffer....I don't even take them off the bike.  Just polish in place.
fuzzybutt
« Reply #12 on: February 17, 2009, 09:59:31 PM »
just use plenty of wenol polish then the protectant.
« Reply #13 on: February 17, 2009, 11:43:14 PM »
I think I'm going to paint them. if they do come out looking like crap i'll bead blast them again. Which kind of rattle can paint would be the best? the VHT engine paint, brake caliper paint, or something else?
Offline Steve F
« Reply #14 on: February 18, 2009, 04:29:14 AM »
Bead blast?    :o  Brave man.
« Reply #15 on: February 18, 2009, 03:26:02 PM »
i've been taping for about two hours  :)
« Reply #16 on: February 18, 2009, 04:03:09 PM »
got my first one done. im cleaning then painting one carb at a time.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline Gordon
  • 750K1, 550K2
« Reply #17 on: February 18, 2009, 05:39:38 PM »
Looks nice!  I hope those bowl gaskets seal perfectly the first time.
« Reply #18 on: February 18, 2009, 06:14:43 PM »
lol yeah im hoping too. if not ill fix any problems, clean them up and repaint the bowls. not a big deal
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline goaarongo
  • zen and the art of angle grinding
« Reply #19 on: July 15, 2010, 07:46:25 AM »
I realize this is an older thread, but I'm curious as to how the paint job held up...
Still out there midnight08?  Carbs still looking awesome?
