I know this has been covered a hundred times and used the search function but couldnt find my answer.
I have a 77 CB750k. I took apart the brake caliper, cleaned the piston and cylinder, used silicone grease and reinstalled everything. The fluid was completely emptied obviously so I buttoned everything up and filling the master cylinder with fluid and I cant get the system to prime. Only getting small bubbles from the master cylinder. I tried pumping with the bleed nipple open and closed. Right now, I have the brake lever held depressed with a strap hoping fluid will eventually leak into the system.
Any tips on how to prime the system? Or do I just keep pumping?
Thanks,
