Author Topic: Want to be sure !!!  (Read 1382 times)
Offline wireman
Want to be sure !!!
« on: February 22, 2009, 02:18:17 PM »
Was just about to cut my new oil lines and run them to my new tank but wanted to be 100% positive I have them correct.  I removed my old dented tank a few months ago and through it out now I cannot remember where they go.  If remember correctly the front is the gravity feed from the tank, and the rear line from the engine pumps the oil to the tank. please help before I cut.
Live life to the fullest!!
75 CB 750    05 Honda 1300 VTX C
WHALEMAN
Re: Want to be sure !!!
« Reply #1 on: February 22, 2009, 02:45:41 PM »
On a 1972 CB750 the front oil line on the engine is the front (closest to oil drain bolt) on the tank.
Offline wireman
« Reply #2 on: February 22, 2009, 02:57:51 PM »
but is the front of the tank closest to the drain the gravity feed or supply from the pump I don't have the old tank.
WHALEMAN
« Reply #3 on: February 22, 2009, 04:23:30 PM »
http://members.tripod.com/cb750K2/Technical/oil1.jpg
This will answer your question. Dan
Offline wireman
« Reply #4 on: February 22, 2009, 05:25:42 PM »
That doesn't work on my computer it just shows up tripod and that's it.
Offline Steve F
« Reply #5 on: February 23, 2009, 02:54:32 AM »
Found this diagram for the 750, and it shows the line TO the tank is the forward-most port on the engine.
Steve F
WHALEMAN
« Reply #6 on: February 23, 2009, 04:07:14 AM »
Try this. Dan
WHALEMAN
« Reply #7 on: February 23, 2009, 04:09:25 AM »
OOPS.
Offline Alan F.
« Reply #8 on: February 23, 2009, 05:44:45 AM »
Maybe this will help too.
Offline cafe2be
« Reply #9 on: February 23, 2009, 08:05:29 AM »
ANy downfall to not running the return tube to the top of the tank?
Offline Steve F
« Reply #10 on: February 23, 2009, 09:35:59 AM »
None that I can see.......
Offline wireman
« Reply #11 on: February 23, 2009, 07:15:24 PM »
I don't see a down fall running to the bottom of the tank but I bought a round tank and wanted it to come in the top so that i can see if the oil pump is working that way i will see it comming out the top.  I did hook it up and I probley didn't need to run it in the top.
