Author Topic: Oil Tank position  (Read 2402 times)
Offline mateo tomas
Oil Tank position
« on: February 24, 2009, 11:54:36 PM »
So I got this oil tank that I am trying to decide how to mount.
I prefer to run it laterally, between the carbs so as to "hide" it.  However, should I be concerned about the heat from the tank as it is basically right up against the mainifolds??
Is this a stupid question with as much resolve as the oil cooler debate???
Will putting beer labels on it because it looks like a keg help cool the oil?????
talk to me goose
____________________
nice big gap
option one
option two
Online mec
Re: Oil Tank position
« Reply #1 on: February 25, 2009, 01:11:37 AM »
this oiltank seems too small. the capacity should be approx. 3.5L oil .
you are doing no good to the engine with less oil.
option two is better cause of better cooling.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
KingCustomCycles.com
« Reply #2 on: February 25, 2009, 02:46:56 AM »
mec
I have been running a quart low with my small Bobber tanks for years.  Modern oils with frequent changes can take the stress.  These engines have lasted thousands of miles and years of storage with poor to no maintenance.  Worse case scenario, you burn one up and have to install another for $175.00.
Offline KB02
« Reply #3 on: February 25, 2009, 10:52:32 AM »
I like option two better. But that's me...   :D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: February 25, 2009, 10:56:57 AM »
Agreed.  The farther away from the hot engine, the better.  Especially when considering the reduction in oil volume.
« Reply #5 on: February 25, 2009, 11:07:14 AM »
plus it looks cool ... why hide it ?
Offline luder
« Reply #6 on: February 25, 2009, 11:09:40 AM »
#2 and it does look better....luder
Offline mateo tomas
« Reply #7 on: February 25, 2009, 06:03:53 PM »
votes are in, #2 it is... besides, it will make checking the oil that much easier  ;)
As far as capacity, it is 3 quarts, but really 2.75ish without over-flowing.  Figure in a little more capacity in the longer oil lines lets call it 2.85 ::)
Offline BIKE
« Reply #8 on: February 26, 2009, 04:19:40 AM »
#2 definately.
1975 CB750 K5
1977 CB750A
Offline Alan F.
« Reply #9 on: February 26, 2009, 06:20:59 AM »
I was wondering what it'd look like if you altered the #2 position by moving the tank back against the inner fender.  You'd gain some cooling and even longer lines, plus you'd crowd your carbs a little less which just might allow better airflow into them.
Offline NickC
« Reply #10 on: February 26, 2009, 07:35:21 AM »
If you moved it back against the fender, you could even fit a small cooler behind the carbs on the frame rails. you wouldnt get a ton of air flow, but it would dissipate heat and increase capacity
Offline nokrome
« Reply #11 on: February 26, 2009, 07:50:00 PM »
i like the up against the rear fender look personally
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
Offline Gordon
  • 750K1, 550K2
« Reply #12 on: February 26, 2009, 07:57:11 PM »
You putting the battery in the seat hump?
fuzzybutt
« Reply #13 on: February 26, 2009, 09:02:17 PM »
position #2 wont make it quite so hard to get to the chain tensioner too.
« Reply #14 on: February 26, 2009, 10:14:22 PM »
#3
Make a triangular one(with radiused corners) to fit where the one with the orange tank sits...............
Offline mateo tomas
« Reply #15 on: February 26, 2009, 10:27:30 PM »
I dig your build btw
Actually planning to attempt a "tank stretch" and hide the lectrics there
#3
If i had the fab skills, I would.
