Well, I got them partly apart. Man that is a lot of work.
Unless you can accuratley drill out a 3mm pin, looks like you will be replacing the entire rack, and shaft along with the brackets..
I got 1 fairly good brace, rubbers are tattered, other brace is rough has crack at screw hole.
