Author Topic: How do I remove Chrome from Rear Brake Panel  (Read 1608 times)
Offline terrapinO
« on: February 25, 2009, 04:37:28 PM »
Hello, I have a cb750K2 and my rear brake panel has a chrome or chrome like coating on it thats flaking off.  I was wondering if anyone knew how to remove it so i can polish the panel. I tried searching the forum but didn't find an answer. I then tried sanding it but that just scratches the chrome, doesn't really remove it.  Would a wire wheel do the trick or is there a way to chemically strip it.  Thank you
Offline wireman
Re: How do I remove Chrome from Rear Brake Panel
« Reply #1 on: February 25, 2009, 04:52:18 PM »
If I know what you are talking about that back piece is polished alum and what you have is the clear coating comming off.  I used very fine sand paper to remove all the clear and they hit it with a polisher came out great.
Live life to the fullest!!
75 CB 750    05 Honda 1300 VTX C
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: February 25, 2009, 05:02:41 PM »
If it is clear coat, you can take it off with Aircraft Remover which is available at most auto parts or home improvements stores.  WalMart carries it too.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline terrapinO
« Reply #3 on: February 25, 2009, 05:27:36 PM »
I don't think its clearcoat. This is what it looks like, sorry for the crappy camera phone pics. the last pic is a flake in my hand of what i am talking about, its silver like chrome and copperish on the underside.
« Last Edit: February 25, 2009, 07:01:52 PM by terrapinO »
Offline NickC
« Reply #4 on: February 25, 2009, 05:32:22 PM »
brake fluid....
Offline kayaker43
« Reply #5 on: February 25, 2009, 05:39:19 PM »
Your pictures don't work but if it looks like chrome and has copper on the back it is chrome plated. The term triple chrome plated really means copper,nickel,chrome. Anyone who does chrome plating can remove it by reversing the process.
No chemical stripper or abrasive will take it off. Probably cheaper to find a used part.
Offline terrapinO
« Reply #6 on: February 25, 2009, 05:44:13 PM »
Thank you, i think i'll start looking for a used part
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: February 25, 2009, 06:28:01 PM »
brake fluid....
If there's brake fluid on the rear brake of his 750K2 then he's got worse problems that he originally thought. :D
edit: after I posted that I realized what you were trying to say... :-[ ;D
« Last Edit: February 25, 2009, 06:29:51 PM by Gordon »
« Reply #8 on: February 25, 2009, 08:07:58 PM »
Is there still places that have not seen chromed aluminum..??
« Reply #9 on: February 25, 2009, 08:13:48 PM »
There is an acid that you can buy that dissolves chrome, i will try and find out what it is called and get back to you.
« Reply #10 on: February 25, 2009, 08:24:30 PM »
That might leave you with the nickel and copper to deal with.
Sandblast may get it off, not much to lose.. or sand it off.
 Thruth tho, cheaper to get another.
« Reply #11 on: February 25, 2009, 08:30:51 PM »
Apparently it gets everything off ready to be painted
Offline Joe Mig
« Reply #12 on: February 26, 2009, 02:10:00 AM »
You could use EZ off oven cleaner to take off chrome and paint.
 Use gloves to protech your hands,
"If everything feels undercontrol...you are not going fast enough"
Offline BIKE
« Reply #13 on: February 26, 2009, 04:11:06 AM »
What is this stuff called?  Is it sold as Aircraft Remover?
1975 CB750 K5
1977 CB750A
Offline Gordon
  • 750K1, 550K2
« Reply #14 on: February 26, 2009, 06:27:21 AM »
Either that or Aircraft Coating Remover, depending on the brand.
