Author Topic: Swapping out fork seals w/o removing forks?  (Read 3037 times)
Offline scartail
« on: February 25, 2009, 06:25:11 PM »
Hope this isnt too green of a question. Can I replace my fork seals without having to remove the fork from the triple tree? I've got a 76 550K. Thanks!!
'89 Hawk GT, newly acquired, daily beater...
'76 CB550, was my daily beater... my cafe project...
'72 Yamaha R5, newly acquired project... donated to my buddy...
'67 Suzuki T20, still working on her too... Currently in pieces...
Krixxer
Re: Swapping out fork seals w/o removing forks?
« Reply #1 on: February 25, 2009, 06:31:07 PM »
If you find a way then I'd like to see it!
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: February 25, 2009, 06:35:29 PM »
It's possible, but I see no benefit to doing it that way.
« Reply #3 on: February 25, 2009, 08:05:20 PM »
Benefit, its quicker, dont have to remove 1 end of gaiter, dont disturb headlight ears, dont have to loosen triple clamp bolts,  if done right dont have to take fork cap off.
Works on 73 and later 750, not sure on 500..
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: February 25, 2009, 10:57:40 PM »
754 is correct.  You could save yourself about 5 minutes of work per fork.
« Reply #5 on: February 26, 2009, 07:59:07 AM »
Bet its not 1/6 hr difference at a Honda dealer.. :o
Offline pablo78cb550
  • mmmph.
« Reply #6 on: February 26, 2009, 09:09:10 AM »
so you're saying you want to leave the inner tubes in the tree?
.... hope it doesn't fall forward and mess up the bottoms.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
« Reply #7 on: February 26, 2009, 09:13:38 AM »
You have to block the bike up, or hang it regardless. It has to be the right style of forks to do this.
I was incorrect stating that you did not have to remove top cap to add the oil.
Offline scartail
« Reply #8 on: February 26, 2009, 02:32:22 PM »
I was thinking it from the perspective of not only time, but the convenience of it already being mounted and not fussing with the head lamp.
Thanks for all the advice guys!
Offline Henrik Vik
  • The K2.
« Reply #9 on: February 28, 2009, 12:10:17 AM »
Can only talk for the bike I have, a CB750 K2, but I guess it will be the same. Yes, it's possible. But it's a lot more work that way. I wouldn't do it like that. If you slide the forks out of the triple trees, the rest is straight forward. Just pull the dust covers up the fork stanchions and loosen the circlips. Then just pull the lower fork legs off. That's it. Off with old seals, on with new ones. Jobs done.
CB750 K2 - Pretty stock...
CB750 F1 - Henry Abe 900 Kit
« Reply #10 on: February 28, 2009, 08:09:56 AM »
It wont work on the K2, at least not by pulling only 1 bolt  per fork leg.
As far as I remember, you have to hammer the seal off on the 72, by repeatedly hitting the seal with the fork bushing.
On the other later style, you can probably pull off both forks with fender still bolted on.
There has to be a flat rate mechanic  out there, that has done this , and made quick money..
« Last Edit: March 13, 2009, 06:57:55 PM by 754 »
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #11 on: March 13, 2009, 05:32:50 PM »
bringing a post back from the dead, but on my 750 K2 I'll need to take the tubes loose from the trees?  Crap, I was hoping I could just drop the lowers and yank the seals without taking the tubes loose.  Oh well, that'll give me a chance to clean everything in there  ::)
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
Offline Gordon
  • 750K1, 550K2
« Reply #12 on: March 13, 2009, 06:38:07 PM »
It's really not much work to remove the forks, and will save you time and effort in the end.  I guess if you were going to be doing this for a living and could benefit from putting the time into learning how to do it faster by leaving the top half of the forks in the trees, then that might be the way to go, but if you only plan on doing this once or twice for the life of your bike, then follow the procedure in your manual.
  • Easily Distracted
« Reply #13 on: March 13, 2009, 10:23:39 PM »
Thanks Gordon, thats what I needed to know
Offline jaknight
  • ....Round Town Ride......
« Reply #14 on: March 13, 2009, 10:49:56 PM »
Hi Guys,
One thing about taking it really all apart......... I did so a few years ago...... man am I glad I did.
A really bad place of danger is under the "fork ears" or "headlight ears", on the top of the tubes that the bolt goes through to hold the headlight in place.  Mine looked perfectly chromed on the outside, but when I dismantled everything...... >:( >:(
The rust on the inside was horrible..... darn near the worst I've seen.  I would never have dreamt there was such bad rust in there.  Very glad I pulled them off to prevent something really bad from happening.......... ;) ;)
Just a thought.......
~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
  • Easily Distracted
« Reply #15 on: March 14, 2009, 11:32:26 AM »
That's the other thing I was thinking about, rust under the headlight ears.  Guess I could clean it up and hit it with some spray paint.
billybobobrain
« Reply #16 on: March 14, 2009, 12:39:33 PM »
Please elaborate on this, do you mean that you take the fork tube and use it in a slide hammer action pulling the fork apart violently in order that one might loosen the seal?
  • Easily Distracted
« Reply #17 on: March 14, 2009, 12:51:20 PM »
From what I can tell, you just pull the snap ring and use the fork lower as a slide hammer.
I think...
 ;D
billybobobrain
« Reply #18 on: March 14, 2009, 01:02:00 PM »
Thank you sir. I will have to give that a try!
Offline goon 1492
  • Sucka Repellant
« Reply #19 on: April 07, 2009, 09:41:34 AM »
Billy how you doin' on the forks?(I will have to check your thread) I got one of my fork seals(silly me forgot to check the ammount box when ordering ::) :P ) and I have to get the other one in before tearing into it, so now I am studying....
I am on the fence about the atf fluid, I have heard mixed things about it but nothing bad, still curious though :-\
  • Easily Distracted
« Reply #20 on: April 07, 2009, 10:51:38 AM »
Got mine back together (after polishing EVERYTHING and doing the disc side swap) The slidehammer trick worked great with my K2 forks, but the new seals were grade A bastards to get back in. I didn't have anything to use for a seal driver, so I had to do the "use the old seal as a driver" trick.  Little suckers went in tight and I was beginning to wonder if I could get them in far enough to put in the snap rings before I screwed them up.  Finally got them in, bolted everything together, filled with Pro Circuit PC01 fork fluid (1 cup is pretty close to 7.5 to 7.8 oz. that Honda recommends) put in my new air fork caps (THANKS RON!! ;) ) and was totally friggin amazed at the difference in how it rode.  Is was like I had to learn how to ride again. It wouldn't bounce when I was used to (like entering a corner) and I never realized that I was compensating for it with the throttle.  Now I realize how #$%*ty the rear shocks are :o
And as for the original question:  If you've never has the forks out and apart (and they havent been apart since it left Japan) for doG's sake, get them things outta there and clean 'em right.  I couldn't believe the kind of crap that came out of those things, and as I expected, my upper fork tubes were a rusty, crusty mess.  clean them on the wire wheel, and smooth them up with some emery cloth.  I smeared them with anti-seize before I put them back in.  They really didn't want to come out that first time!
Hope this helps!
Offline jaknight
« Reply #21 on: April 07, 2009, 01:09:59 PM »
Hi Guys,
That's why on mine, I was glad I took them completely apart.  Mine was a rusty, corroded mess...... :P :P
Offline Johnie
« Reply #22 on: April 07, 2009, 03:27:43 PM »
If you are spending the time to change the seals you are correct, take them apart and clean the crap out of them.  Chances are they have never been cleaned since built.  I just like to do it right and not cut corners.  How can you go wrong with new seals, clean uppers and lowers and new fork oil.  I would hate to dump clean fork oil into the crap that was on the bottom of my KO & K1 forks.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline goon 1492
  • Sucka Repellant
« Reply #23 on: April 08, 2009, 06:41:12 AM »
You all said it right; mine barly had any thing come out of the right fork tube, a little shot of primodial goo and a tbsp of fluid. The leaky side(left) was a different story, I pulled the drain plug and it almost shot out of my hand and shot a plug of goo along with a stream of fluid out and three feet across my shop floor. Best part is I ruined the back side of a perfect piece(one piece not two glued together) of red oak that was 36in x 15in :'( :'(. it took the main stream of fluid and blocked the laundry form getting it.
Does fork oil smell? Mine smelled like rearend diff fluid  ??? I have never torn into forks yeet so I wanted to ask.
I will post some pics when I get things apart, one other thing what is this broom stick I have read of?
My bike is a 67 750k but I think the forks are newer because the front had been wrecked or in a ditch at one time and now has some k8 parts on it.
« Reply #24 on: April 08, 2009, 07:47:55 AM »
"Tired of the Same Old FORKING Thing?,
Try SEAL SWAPPING ! :o"
Starting to sound like this should be in the personal Ads.. ;)
