new plugs, - old ones pretty oiled up & black
when bike was warm smoke coming out of breather tube under battery like steam out of a kettle (colour blue and definitely oil).
Oily plugs? How did oil get in there? Preservative storage, valve guides, rings?
The crankcase can be pressurized by:
Water/condensation boil off into steam vapor.
Leaking piston rings. on compression and power stokes.
I'd like to see the results an engine hot compression test, with another test imediately following with a teaspoon of oil dumped into each spark plug hole. If you don't already know the proper proceedure for a compression test, ask.
Possibilities:
1 - After the engine heats thoughoughly the water get competely vaporized and the smoke stops.
2 - Stuck or seized ring(s) free up with use, reseats and seals, reducing the smoke volume. This can sometimes be "encouraged" by dumping some Marvel Mystery oil into the spark plug holes and allowed to soak overnight.
3 - Permantently seized/scorched rings, broken rings, or scored cylinder walls must be renewed to seal properly.
4 - worse
