SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
brocken oil pan bolt
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: brocken oil pan bolt (Read 1809 times)
lifeofthe88@yahoo.
Guest
on:
October 12, 2005, 07:38:55 PM »
what is the easiest way to get this bolt off.went to remove the pan and one out of the ten broke off.cant get grip on it.deciding weather or not to leave it as is
Logged
lifeofthe88@yahoo.
Guest
Re: brocken oil pan bolt
Reply #1 on:
October 12, 2005, 07:48:18 PM »
oil filter housing wont come off also.really starting to hate this project
Logged
Buffo
Guest
Reply #2 on:
October 12, 2005, 07:55:33 PM »
I got 2 of my favorite tool sets from sears...one is a group of sockets(?) that grab on to rounded nut and bolt heads...and any other shaft that needs to be spun...they kinda cut/bite into the metal ans force it to turn...the more you turn the deeper they cut/bite untill whatever it is comes out or...favorite tool #2 comes out...
these are dril bit looking things that first drill a hole into the bolt/screw to be removed...then an awger(?) of types bores into the hole and uses the same type of priciple as the later tool scoket set...reverse theads cut/bit into the hole you drilled...the more you twist the harder more it digs in...these are good for bolts/screws that have busted off heads
Buffo The Magnificent
Logged
lifeofthe88@yahoo.
Guest
Reply #3 on:
October 12, 2005, 07:59:52 PM »
hmmm guess ill probably have to get more tools. thought i had everything i needed.its too deep to get a grip on it.thoght i could find something laying round the garage that would work.
Logged
Kelvin8
Guest
Reply #4 on:
October 13, 2005, 12:20:50 AM »
Don't you just hate it when you HAVE to buy more tools?
All right, it's a drag when you're in the middle of a project ...
Logged
Alan F.
We remember the Night Rider, and we know who you are.
Really Old Timer ...
Reply #5 on:
October 14, 2005, 12:43:23 PM »
here's the old method to remove the filter bolt when all else fails..........gring the head off of the bolt and slide the housing off, then grab the bolt with visegrips and remove it (heat may help) new bolts are available
Logged
Free Fork Swaps and Upgrades info parked at
https://ariesmotorcycles.com/list-of-motorcycle-reference-documents/
750K3 build:
http://forums.sohc4.net/index.php?topic=46082.0
750K8 build:
http://forums.sohc4.net/index.php/topic,182592.0.html
Black Friday a red CB160
https://tinyurl.com/Black-Friday-a-red-1965-CB160
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
