Author Topic: neck stem size  (Read 6544 times)
Offline dusterdude
neck stem size
« on: October 08, 2005, 11:02:19 AM »
does anyone know the neck stem diameter on a k1 750 triple tree.thanks
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Alan F.
Re: neck stem size
« Reply #1 on: October 08, 2005, 12:35:26 PM »
I made a drawing with the measurements, but the cd it's on is at work, I'll post it on monday.
Offline dusterdude
Re: neck stem size
« Reply #2 on: October 08, 2005, 01:47:32 PM »
cool,thanks
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Alan F.
Re: neck stem size
« Reply #3 on: October 08, 2005, 04:11:58 PM »
or I could measure some specific part sooner, I've got a 78 750K tree and a cheap vernier caliper here at home.....
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
Re: neck stem size
« Reply #4 on: October 08, 2005, 04:22:15 PM »
How much do you want for the treeX3.  Quails@juno.com
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
Offline Alan F.
Re: neck stem size
« Reply #5 on: October 08, 2005, 04:51:56 PM »
You may not want this particular triple tree, I'm saving this one for a swap to some sportbike front end....I've ground the weld off the bottom, but I haven't pressed the stem out yet, sorry.
Offline dusterdude
Re: neck stem size
« Reply #6 on: October 09, 2005, 10:13:30 AM »
ss,you mean it has two different size bearing surfaces?
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline dusterdude
Re: neck stem size
« Reply #7 on: October 09, 2005, 10:23:09 AM »
wow!!!,thanks for the info
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Re: neck stem size
« Reply #8 on: October 10, 2005, 03:58:57 AM »
Not only are they different but they are also "oddball" when tied up with the outers diameter so yoiu cant just go and buy bearings you have to get one of the "kits"
Offline dusterdude
Re: neck stem size
« Reply #9 on: October 10, 2005, 04:09:42 AM »
damnit jim,ok anyone know what it will take to put a 78 gw front end on a k model.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline frostypuck
Re: neck stem size
« Reply #10 on: October 10, 2005, 08:30:59 AM »
How about this...http://www.realmagicwands.com/
Just kidding, it should be a fairly direct swap. Did the '78 GW have spoke wheels, or had they changed over to cast, by that time? I'm thinking the same transplant, but want to keep the spokers which is why I haven't grafted a later F onto a K, yet.
Chris in Boston
Boston, MA, USA
Offline dusterdude
Re: neck stem size
« Reply #11 on: October 10, 2005, 10:28:43 AM »
chris,i missed a spoke wheel on ebay yesterday that was supposed to fit the 78 gw front end.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Geeto67
  • A grumpy
Re: neck stem size
« Reply #12 on: October 10, 2005, 01:32:45 PM »
have you tried posting the same question on hondachopper.com? there is at least one guy there who has tried the later gw front end swap and maybe can help you.
I thought 78 was the mag wheel on a GW. When I look up fork seals and headstock bearings I always see it as 75-77 (76-77 in some cases) sO I always assumed it is different. For doing the 75 swap I have, it takes one cb750 temkin bearing ( I think the lower) and one GL1000 temkin bearing (I think the upper, but I would test fit to make sure). If the bearings are listed as the same for the 78 - I'd try this approach first, you might find the solution is that easy.
I had a friend who was into kawi z-1s, and also worked in a bicycle shop. One night we raided every ball bearing in the joint and started expirementing. The end result: with two different oddball bearing sizes and two flat washers we were able to adapt a ducati 916 front end to his 1975 kz900 streetfighter project (and yes it was safe to ride). This only works on bikes where the original bearings are not temkin bearings (like your GL1000 and cb750 front ends).  I know that in racing some of the fzr400 guys use bearcans to shim their headsotck bearings when the headstock goes out of round so that might be a possible source for shims.
Most of the guys on this board seem to be more into the stock stuff, so custom stuff doesn't get that much of a response. The best way to find out if a GW front will fit in your cb750 is to get your arse in the garage  and start messing with it.
Maintenance Matters Most
Offline Geeto67
  • A grumpy
Re: neck stem size
« Reply #13 on: October 10, 2005, 01:46:23 PM »
ok here is what I can tell you
The 75-76 gl1000 neck bearing size is:
Upper: 26 x 48.5 x 15.2
Lower: 30 x 50 x 14.4
The 77-79 Gl1000 neck bearing size is:
Upper: 25 x 47 x 15
Lower: 30 x 55 x 17
and the cb750 neck bearing size is:
Check out this link for bearin size interchanges:
http://www.hortoncustoms.net/hardcore/viewtopic.php?t=885
The GL100 uses 37mm forks from 75-79. When you get your front end measure the distance between the forks. I'll measure my 75 trees. If they are the same, maybe you can resell your 78 trees and get a set of 75 trees to mount the front end to a cb750.
« Last Edit: October 10, 2005, 01:49:10 PM by Geeto67 »
Offline dusterdude
Re: neck stem size
« Reply #14 on: October 11, 2005, 05:09:58 AM »
ill certainly do that,thank you very much for the info.you guys are the #$%*,i think im gonna cry. :D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline dusterdude
Re: neck stem size
« Reply #15 on: October 13, 2005, 12:48:54 PM »
do the aftermarket timken bearing conversions use the same bearing cup that fits in the frame neck as what is standard on the 750?
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
