Author Topic: Help identify my case issue  (Read 6076 times)
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
Re: Help identify my case issue
« Reply #25 on: April 04, 2009, 05:16:19 PM »
That can be welded up,both sides,then they can be shaped and dressed up with files and sandpaper.I have redone cases with 3 finger sized hole and no case chunks to weld in.
A good welder can build up,and or reattach chunks,rather easily.Inspect the top case in the chain area,clean it good and use a good light to see if there are any small cracks there which could be addressed by the welder at the same time. I put a chain threw a set of cases
(top & bottom),fixed it and that motor is still running fine today.That was in the summer of 1975.     Head
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
Jamil20
« Reply #26 on: April 04, 2009, 07:20:01 PM »
Excellent. Thanks for those words of encouragement. I'll go take a look at the upper case.
Jamil20
« Reply #27 on: April 04, 2009, 07:29:15 PM »
There appear to be 3 cracks on the upper case. They look superficial for the most part. I don't know if I should get them fixed. This means having to disassemble the upper case completely as well. Or maybe he can do it with everything still inside?
I managed to get a bunch of dust inside as well.
Offline Head
    • My Bikes
« Reply #28 on: April 04, 2009, 09:16:32 PM »
I would let the welder take a look at that upper case,let him determine a solution,I think that should be looked at! A good welding blanket is a wonderful thing.     Head
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #29 on: April 04, 2009, 09:42:58 PM »
Go for it man! When I built my 396 for my Chevy I found a large crack leading from the oil galley up through the head mating surface. I found a small shop with an 'old timer' and he had me fixed up in no time flat. I know how you feel, where I live desireable old engines of any make are pretty rare.
The only advice I can lend is don't skimp on cleaning. If you have to disassemble everything to get it clean then do it. You can scour a main bearing pretty easy by skimping on cleaning up the guts.
1974 CB550
Forever West
« Reply #30 on: April 04, 2009, 09:59:58 PM »
Top case.
You can leave the topend on. Flip motor over and build cradle to hold it level out of 2x4s. Mask the hell out of the crank and trans. Might have to remove 1 trans shaft.
 Half the battle is making the piece, your botom still has it so good. As for the point area, a bit tougher, maybe someone has a donor case they can cut those pieces off( bad part is  happens quite a bit)
Jamil20
« Reply #31 on: April 04, 2009, 10:10:40 PM »
I think I may need to disassemble and wash everything. There are so many particles inside the case now, I'm probably asking for it if I don't.
fuzzybutt
« Reply #33 on: April 04, 2009, 11:55:51 PM »
Jamil, where are you located? if youre in the southeastern us i think i can come up with some good cases for you
Jamil20
« Reply #34 on: April 05, 2009, 07:22:18 AM »
Ottawa, Canada.
Don't think anyone else is out here. I think some people are in Montreal, which isn't too far away.
« Reply #35 on: April 07, 2009, 08:36:06 AM »
Ottawa, Canada.
I have a spare K8 engine (10,000 miles) in Boston, MA - we just got a parts bike. I was going to take the engine but you seem to be in more need than I. Let me know what you think. 5 hr drive from Montreal.
cheers
Andy
Jamil20
« Reply #36 on: April 07, 2009, 08:40:02 AM »
cheers
Andy
Thanks, Andy. Let me know what you want for it. Might help me determine the cost/benefit ratio. I haven't found a welder yet, but then I haven't looked much. In the middle of house shopping.  :-[
Offline Toxic
« Reply #37 on: April 07, 2009, 12:39:42 PM »
Ottawa, Canada.
Jeez Dude don't give up.  I just read your whole post.  I'm in Ottawa.  There was  a fellow selling a complete 73-75 for very little money. He was in Montreal, not that far.  I have a bunch of spare stuff but not a spare engine.  Send me a pm with your number and I'll see what I can dig up.
Gary
Jamil20
« Reply #38 on: April 07, 2009, 12:43:10 PM »
Gary
Thanks Gary. I'm not giving up by any means. Just weighing my options. :) This is a running engine after all.
I sent you that PM.
« Last Edit: April 07, 2009, 12:45:51 PM by Jamil20 »
« Reply #39 on: April 07, 2009, 01:11:09 PM »
I think the going rate is around $100 - ( engine <10,000 miles). Pick up only though unless you find someone to come by and pick it up.
cheers
Andy
