Author Topic: CB550 Tire sizes  (Read 6510 times)
sipesracing
CB550 Tire sizes
« on: March 04, 2009, 09:13:29 AM »
What is the biggest or should I say widest rear tire that will fit on the 74-78 cb550 .And the biggest tire that will fit on the front .. I am looking for a track tire but DOT or an old Vintage race looking tire .. Thanks
admiket
Re: CB550 Tire sizes
« Reply #1 on: March 04, 2009, 10:07:34 AM »
120/90-18 rear
100/90-19 front
this is what i run on mine. there is a ton of stuff under search. i wouldn't go any larger then this or you will get funny wear.
« Reply #2 on: March 04, 2009, 11:10:51 AM »
You'll get funny wear with oversize tires on the stock narrow rims.  Certainly with a 120 rear.  I wore out two consecutive Dunlop 120s on the back of my 550s in less than 5000 miles.  They squared off and lost center tread very quickly, and this ruined the bike's neutral handling.   While the 120's fit within the fenders, they are a marginal fit onto the 1.85 rim width.  While I haven't tried 100's on the front, I would rather expect the same type of handling issues would develop as the front tire "squared off" with use.
The narrow rim size changes the desired side will angle on the rim for a tire designed to go on a wider rim.  This weaknens tread stabilty, centered on the rim.  To compensate, higher tire pressures are required.  This wears the crown of the tread faster leading to the tire "squaring off".  They OS tire handle well when new, while they still have that new crown.  But, the closer you get to replacement time, the worse the bike's handling becomes, forcing the rider to change riding habits to compensate.  You REALLY notice it when you get a new tire that restores handling.  It's a false euphoria, though, and lost as riding time increases.
I've gone back to the standard size tires for the 550; 3.25 Front and 4.00 rear. (Can't find a 3.75 tire I like.)  They can still be ordered from manufacturer, even if the local tire Hawk doesn't stock them.
I've been happy with the Metzlers, and they've been wearing evenly, so far.  There are still other good brands that make standard size tires, though they are dwindling as more people, put "modern" tire on these old bikes.
Offline Otto
« Reply #3 on: March 04, 2009, 01:11:54 PM »
Two Tired,
So is it correct to assume that a 550 (mine is a 76 550K), should have :
90/90 - 19 Front
100/90 - 18 Rear
It seems when I look for tires , I can never find a set where one or the other size isn't offered. i.e. the front tire is made  by by XYZ, ( Avon, Metzler, Brifgestone)in a 90/90  , but the 100/90 - 18 rear, isn't offered by the same manufacturer in the same series...
Am I the only one seeing this... ? Or any reccommendations for ONE manufacturer offers the front and the rear in the same series.. It must be out there.
Maybe I just haven't found it yet.
Thanks-
bc
Otto
1971 HONDA CB750K1- Valley Green Metallic
2007 Triumph Bonneville - Silver/Black Carburetted
« Reply #4 on: March 04, 2009, 02:18:57 PM »
Stock front tire was a 3.25" with a 100% aspect ratio  (3.25" tall).
A 90/90 is  ~3.60" wide and ~3.24" tall.  Your speedometer drive ratio won't be off by much.
Stock rear tire was 3.75"  and 100% aspect ratio (3.75 tall).
A 100/90 tire is ~3.9" wide and ~3.6" tall.  Your engine will rev higher at the same speed compared to a taller tire.
A 110/90 tire is ~4.4" wide and ~3.96" tall.
So, your selection is fairly close to what Honda selected for your bike.  If you absolutely must substitute, these should work.  All these should fit within the fenders.
You should check with the tire manufacturer though, and make sure that a 1.85" rim width is within the tire's design specs.  When metric sizes were introduced, wider rims also occurred on the newer model bikes.
Of course, there is the point of view that only the inch sizes are truly correct for the bike, if you want the nice stock neutral handling. ::)
