Author Topic: Handle Bar Help  (Read 2750 times)
danramoz
Handle Bar Help
« on: April 16, 2005, 03:16:34 PM »
I could use some help bad.  I am putting the handle bars of a 75 CB400f on a 74 CB350f.  I was told it would work fine.   I have them on and now I realize that my master cylinder/front brake housing doesn't fit on the bars with the starter/throttle assembly.  Does anyone know if the 400's had a smaller master cylinder than the 350's?  Does anyone know if this set up is even possible?
I would appreciate any feedback at all.
Thanks!
danramoz
Re: Handle Bar Help
« Reply #1 on: April 16, 2005, 06:38:12 PM »
I finally got it to fit.  Just needed some tweeking and had to move the oil bolt on the master cylinder slightly.  I was referring to the actual length of the bars.  I was having space issues with the master cylinder not fitting between the starter assembly and the speedometer.
Thanks for your reply.
