Double check your fuses. There may be internal damage you cant see.
one way to test:
With the key on, kill switch on, put the leads of a volt meter across the fuse. There should be ZERO volts. If you get a voltage, replace fuse.
2nd way to test:
Pop the fuse out. Put the leads of an ohm meter (1K or there abouts setting) across the fuse. Should read read ZERO ohms.
