Author Topic: Would you reuse a not so perfect cam sproket?  (Read 1962 times)
Offline tinyrobot
  • Mock it up before you Fock it up!
    • ChiVinMoto
« on: March 16, 2009, 07:21:48 AM »
So in my CB550 rebuild I got the cam out and noticed that the sprocket has some nicks and chips in the flat side part of it.  The teeth are perfect as is the inside.  Would you reuse a imperfect cam sprocket if the teeth are still prefect?
Also where can I get a new one if you guys think it is not reusable?
Offline meb1948
Re: Would you reuse a not so perfect cam sproket?
« Reply #1 on: March 16, 2009, 07:45:43 AM »
The sprocket (pn 14321-323-000) is no longer available from Honda.  If the teeth are in good shape and there are no cracks, I would reuse it.
Otherwise, I'd check the after market manufacturers to see if anyone is making camshafts for the 1975 CB550K.
Mark
Mark
1976 Honda 400f
1976 Honda 750f1
1980 Kawasaki KZ1000
1989 Saleen SSC #170
2001 Mustang Cobra Convertable
Offline tinyrobot
    • ChiVinMoto
« Reply #2 on: March 16, 2009, 07:48:04 AM »
I know there are several makers of camshafts, but I don't believe I have seen aftermarket cam sprockets.   :(
« Reply #3 on: March 16, 2009, 08:04:58 AM »
Jay @ APE has adjustable cam sprockets for 750.
 Does anyone on here know, if 750 & 500 & 550 interchange?
Offline tinyrobot
    • ChiVinMoto
« Reply #4 on: March 16, 2009, 10:45:30 AM »
Good to know I will look into the interchangeability.
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #5 on: March 16, 2009, 11:18:13 AM »
does anyone have the addy of that interchange chart that was posted a few days ago?  That would be perfect!
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
Offline tinyrobot
    • ChiVinMoto
« Reply #6 on: March 16, 2009, 12:08:03 PM »
Well after looking at some parts micro fiche, looks like the CB500K,F and the CB550K,F have the same number and look of the cam sprocket.  The 750s, 650s, and 450, are all different.   :-\
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #7 on: March 16, 2009, 12:19:29 PM »
If the teeth are good, go with it.
How about posting a picture?
FJ
Offline tinyrobot
    • ChiVinMoto
« Reply #8 on: March 16, 2009, 12:21:11 PM »
Now looking at some pictures off ebay, I see the teeth count are the same for many vintage honda sprockets = 34 teeth.  The look of the 350 sprockets is similar???  I know there are adjustable 350 sprockets out there too.
Offline tinyrobot
    • ChiVinMoto
« Reply #9 on: March 16, 2009, 12:21:45 PM »
FJ
I'll take a few tonight and post em.
Offline fmctm1sw
« Reply #10 on: March 16, 2009, 03:42:21 PM »
Somewhere here there is a thing you put a part number in and it spits out all the bikes that used that part number..  very cool...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline tinyrobot
    • ChiVinMoto
« Reply #11 on: March 16, 2009, 04:07:22 PM »
here ya go!  Sorry for blurriness, it didnt look so bad on the camera  ::)
billybobobrain
« Reply #12 on: March 16, 2009, 04:12:16 PM »
The teeth might be the same, but looking at the picture there is an offset in your gear, and the 750k, and f cams both have no offset.
Offline mystic_1
  • 1970 CB750K
« Reply #13 on: March 16, 2009, 04:25:49 PM »
That may not be an offset, I've seen OEM cam sprockets that had rubber material of some sort bonded on both sides, perhaps to quiet the cam chain as it rides over the teeth?  That's what it looks like to me.
mystic_1
- John Augustus Shedd
billybobobrain
« Reply #14 on: March 16, 2009, 04:52:13 PM »
I haven't seen that, but if that's the case then the rubber is chipped and I would probably just use the thing. Maybe remove the rubber that is coming apart first so it didn't clog any oil passages.
Offline mark
« Reply #15 on: March 17, 2009, 09:05:15 PM »
I have a spare sprocket that had crunchy rubber....
it strips off easy enough.
better than finding it all in the screen later.
F you mark...... F you.
