Author Topic: Do I need a diffuser on 341's ?  (Read 2606 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: March 16, 2009, 12:22:04 PM »
I found a cheap set of 341 pipes for my 750.
They didn't come with diffusers.
Do I need them? Will it be super loud without them or will it alter the performance by messing  up the exhaust gas flow, etc?
Thanks
Offline Caferacernoc
Re: Do I need a diffuser on 341's ?
« Reply #1 on: March 16, 2009, 02:49:15 PM »
It will be pretty loud, not as loud as short drag pipes or 4 into 1 with megaphone, but on the loud side. And you may need to up the main jet for perfect running.
Offline Kevin D
  • SE Michigan
« Reply #2 on: March 16, 2009, 03:06:49 PM »
I'm running 341's without diffusers on my K1. Sounds nice, of course louder than stock, but far from offensive. Stock air box with foam filter. 115 main 38 slow, 1 step down from stock on both but it would be OK with 120 main and 38 slow,just have to ride harder :)
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline grumpy
« Reply #3 on: March 16, 2009, 03:28:01 PM »
cool.
Thanks!
Offline Spanner 1
« Reply #4 on: March 16, 2009, 04:07:58 PM »
341 exhaust run without baffles ( diffusers ) HAS to be the sweetest sound on Earth !!!
Offline grumpy
« Reply #5 on: March 16, 2009, 06:12:17 PM »
HA!
Maybe so but I don't think the wife & neighbors would agree when I leave for work at 5:50 in the friggin AM
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #6 on: March 16, 2009, 06:25:29 PM »
Having had both, I'd say HM300's are that much sweeter than 341's without baffles.
In the sweetest sound on earth category would also have to be the RC 166...that crazy little 6
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline Spanner 1
« Reply #7 on: March 16, 2009, 06:44:17 PM »
341's; throaty,open sounding, a hint of 'burble', medium to dense 'backdraft' on over-run, subtle harmonics and 'pocking' thru' medium range rpm...and a nice flourish at up-changing !!!
Offline grumpy
« Reply #8 on: March 16, 2009, 07:00:11 PM »
 :D :D :D :D :D
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #9 on: March 17, 2009, 12:40:04 AM »
;D You sound like your tasting wine.  :P
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline Jonesy
  • Shop Rat
« Reply #10 on: March 17, 2009, 04:16:05 AM »
+1 to all of those remarks!!!
« Reply #11 on: March 17, 2009, 05:32:24 AM »
Gotta join this one!  ;D
Wouldn't you love to buzz to work on an RC166? That's kinda why I'd like a 350F one day.
luckydevil
« Reply #12 on: March 17, 2009, 05:55:25 AM »
Ummm....
What are 341 pipes?   ???
Offline grumpy
« Reply #13 on: March 17, 2009, 07:06:56 AM »
Ummm....
They're later model OEM pipes for 750 Ks
http://www.cmsnl.com/products/muffler_00000kit0083/
The K0 & K1 pipes are known as 300s.
luckydevil
« Reply #14 on: March 17, 2009, 06:43:20 PM »
O Tay, Cool
'spensive, but Cool
