Author Topic: Replacement front brake lines for 78 CB750F  (Read 685 times)
Offline mikecan
« on: March 16, 2009, 12:42:07 PM »
Has anyone done a 2 line conversion for the front brake lines for this model?  What lengths worked for you?  I would like to run 2 lines directly from the master cylinder to the calipers and eliminate the junction block behind the horns.
Thanks
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
Re: Replacement front brake lines for 78 CB750F
« Reply #1 on: March 16, 2009, 01:35:59 PM »
If you go to a modern master cylinder it has an integral brake switch that will further let you do without the junction block.
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
