Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Total Members Voted: 20
This is not a pod threadThis is not a #$%* on my vacuum gauges threadThis is a help or GTFO thread.
Am I missing something on that last post . . . . "delivered to your door now. . . ." But really, where can you get them? Between my son and I, we have four bikes that all act like a sync job is in order.
F you mark...... F you.
Alright, the cheap Motion Pro carb synch tool I got a while ago sucked (literally). I want to synch my carbs with a decent tool that will be fairly accurate and durable. I don't mind spending more for the more expensive dial set if it is worth the extra moolah (it is about $100US more than the morgan). Which do you guys recommend I get?
got a deal on mercury sticks that someone had bought and never used.as for the other sync tool........... had a long skinny screwdriver. found a nutdriver with a hollow shank. cut nutdriver handle down so screwdriver would reach screw...... instead of $20 + freight for the motion pro gadget:
Brilliant... I just wonder if I would know how to determine one that has a hollow shank
Quote from: mark on March 17, 2009, 10:54:27 PMgot a deal on mercury sticks that someone had bought and never used.as for the other sync tool........... had a long skinny screwdriver. found a nutdriver with a hollow shank. cut nutdriver handle down so screwdriver would reach screw...... instead of $20 + freight for the motion pro gadget:Brilliant... I just wonder if I would know how to determine one that has a hollow shank
